British Columbia British Columbia
Join Chapter, Leader: F350towing
4x4 issues
Old Oct 31, 2007 | 05:46 PM
DeezDay's Avatar
DeezDay
4x4 issues
anyone have any ideas what could be wrong with my 4X4, 93 ranger manual hubs, push button 4X4 nothing happens, push button and no lights come on, when i take the switch out and use my test light there is power getting to the switch i have no idea. Has anyone ever had this problem or have any ideas.
thanks
Old Oct 31, 2007 | 06:47 PM
preppypyro's Avatar
preppypyro
I would check the ranger, or some of the drivetrain forums man. There you can get alot more specialized help then in here!
Old Oct 31, 2007 | 10:20 PM
Digger6's Avatar
Digger6
I would say it would be the actuator on the trasfer case, the push button chevys were famous for failling
Old Nov 1, 2007 | 10:17 PM
Bandit-1's Avatar
Bandit-1
you could try testing the switch or use a jumper wire to bypass the switch
Old Nov 2, 2007 | 11:41 AM
DeezDay's Avatar
DeezDay
how to use jumper wire
hello, bandit i am just wondering how i would bypass the switch or use a jumper wire any ideas. and thanks alot for everyones help.
Old Nov 3, 2007 | 08:32 AM
preppypyro's Avatar
preppypyro
When you press the button can you hear anything happening down below?
Old Nov 4, 2007 | 10:54 AM
Bandit-1's Avatar
Bandit-1
you would have to figure out witch wire the switch gives power to then use a peice of wire a couple inchs long with some aligator clips on the end of something.
Old Nov 9, 2007 | 10:32 AM
preppypyro's Avatar
preppypyro
Having any luck fixing it?
Old Nov 15, 2007 | 12:12 AM
R031Kona's Avatar
R031Kona
the fix
I just fixed my 91 Ranger transfer case with a 1 /12 work and some elbow grease and 5/16's fuel line. The link https://www.ford-trucks.com/forums/s...d.php?t=123542 read the whole thing first though and it doesn't hurt to google it and read more sources.
Old Nov 15, 2007 | 09:49 AM
preppypyro's Avatar
preppypyro
That is an excellent link r031 thanks for posting it!
Old Nov 15, 2007 | 09:28 PM
R031Kona's Avatar
R031Kona
It really does help to have it on a bench unless you have a helper or three hands IF you take apart the motor itself. The brushes for the armature really are a pain , I did mine in a lube bay and proped it on the transfercase skidplate. Took me 5 try's to get the armature in place :-)
Old Nov 18, 2007 | 10:26 AM
preppypyro's Avatar
preppypyro
Hey 5 trys isnt that bad at all, especially when you succeed in the end.
cbrd1999
1983 - 2012 Ranger & B-Series
May 30, 2017 04:50 AM
DeezDay
Nov 1, 2007 11:56 AM
Wild Karrde
Mar 17, 2007 07:57 AM
ldselder32
Feb 2, 2006 01:31 PM
