low compression
Old Jan 1, 2001 | 08:46 PM
roscoe's Avatar
roscoe
low compression
Old Oct 10, 2002 | 05:55 PM
northernford4x4's Avatar
northernford4x4
low compression
I just did a compression check on my 300 4x4 , and this is what I had ,,, 1 120 2 120 3 115 4 130 5 135 6 95 , they all went up when I pour in oil in the spark plug holes . My question is , are the valves still good and the rings shot or the other way around???
Old Oct 10, 2002 | 07:03 PM
tetraruby's Avatar
tetraruby
low compression
How many miles do you have on the engine? The oil test indicates worn rings, but if you have a few miles & she's eatin' a little oil - might as well have new guides and seals put in too. Those numbers are not horrible, but you have quite a range from 135 to 95 - that's the part to be concerned about. General rule is +/- 15% from highest to lowest..your span is considerably higher.
