help please /2000 mountaineer
Old Oct 31, 2007 | 08:50 AM
tatata's Avatar
tatata
Car will only stay on if I continue pressing on the accelerator.Any suggerstion on what the problem could be .I had to drive it back home with my foot on the brakes and on the accelerator so it would die on me.
Old Oct 31, 2007 | 09:12 AM
97 Mountain Man's Avatar
97 Mountain Man
It could be a vacuum leak or your IAC valve.
Old Oct 31, 2007 | 09:18 AM
Backin72's Avatar
Backin72
Yup, most likely the IAC.
Old Oct 31, 2007 | 10:08 AM
tatata's Avatar
tatata
Im pretty new at this, so would that be something that I should take it to the mechanic or is something I can do my self . thaks for everyones help
Old Oct 31, 2007 | 10:20 AM
Backin72's Avatar
Backin72
Pretty easy. Here's a link for the Explorer IAC. Shouldn't be much different for the Mountaineer.
https://www.ford-trucks.com/article/...r_IAC_Fix.html
Old Oct 31, 2007 | 10:31 AM
tatata's Avatar
tatata
Thank alot link is very helpfull I will replace the IAC my self . Thanks again
Old Oct 31, 2007 | 10:36 AM
Backin72's Avatar
Backin72
No problem, good luck, and don't forget the gasket. Check to make sure it comes with one. You may have to buy it seperately.
Old Oct 31, 2007 | 11:48 AM
97 Mountain Man
If you have a 5.0 it will be on the right side by a plastic cover that goes over the throttle & cruies control cables.
Make sure the conector is on the left side as you are looking at it from the front. The one I bought was on the bottom and was a little tight getting on because it sits right against the cover I mentioned above.
A new one should rn around $50
