harmonic balancer....uh...do I have one?
Old 10-09-2008, 11:11 PM
dfwrider's Avatar
dfwrider
dfwrider is offline
Update: I finally got around to addressing some issues, trying to isolate the vibration. Installed new motor mounts, carrier bearing assembly, harmonic balancer, transmission mount. Still got the vibration. Which I only get at 40 mph and under, when stomping on the gas (1st or 2nd), vibration increases with RPMs.
On the highway, she's pretty smooth.
The one thing I haven't done is add shims to the axle perches. I suspect when I had the entire rear axle swapped, that when they welded my perches on the new axle, they were slightly off...and perhaps tipping the output slightly up.
I do have, separate from the vibration, an occasional "shudder", as I start to let out the clutch from a standstill.
Oh well. Making progress. Thanks for all the suggestions.
d
Old 10-10-2008, 12:58 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1965/67 F100/350 352 Harmonic Balancer aka Damper
FY1
C3AZ6312E .. Harmonic Balancer.
Fits: 1965/67 F100/350 352 / 1960/67 Passenger Cars w/352/390's
Reproduced
Available here: dearbornclassics.com / 800-252-7427 / Online Catalog / Page 152 / Dearborn's part number: HAB10.
Old 10-10-2008, 09:28 AM
JimKoz's Avatar
JimKoz
JimKoz is offline
Shudder when letting the clutch out is commonly caused by oil on the friction disc and flywheel.
The oil causes the clutch disc to "wind up" the drivetrain only a little bit before losing its hold. The cylcle repeats many times per second as the clutch is let out.
Anything in the drivetrain that isn't rigid, like a broken motor mount or weak rear springs will make the problem feel worse because the drivetrain components can "wind up" more before the clutch slips, causing a slower and more violent shudder.
Old 10-10-2008, 02:49 PM
billy12360's Avatar
billy12360
billy12360 is offline
Originally Posted by Redmanbob
Yep one of the favorites in my little list The carrier bearing will have to be pressed at a machine shop most likely. I did mine in the driveway.. just mark/scribe things for alignment and walla. The mounts are easy just in a tight spot but not that hard to do at all. Be safe in there though as that FE weighs a **** load..
haha anything in these trucks weigh right around that much... i was talking with a family member who just bought a brand new dodge truck and said he was having problems with the electric windows... i go yeah... i only have to worry about 10 fueses at the most going out hahahahahahaha he goes why? you truck doesnt have power windows? and i reply NOPE it was made in 63... then later we where driving around town and drive right past a 61-63 2wd or 61-66 4wd and i pointed it out to him, and go thats what my truck looks like.... and he goes OHH those things... does it have the 4speed with granny low,.... mhmm.... he goes stupid POS cast iron trannys hahahaha we had one in our 70 something f-100 and we where trying to put it back in ended up not being able to bench press it in so we ended up wraping a chain threw the opened doors and running a come along down the shifter hole and lifting it back into the truck that way...
i figured since i think youve figured everything out succesfully i would tell a little story from last night..
Old 02-09-2009, 10:29 PM
rsdjcarter's Avatar
rsdjcarter
rsdjcarter is offline
I have a question on this Harmonic balancer issue. How do you tell if the rubber bushing is worn out? is it visible? I figured the balancer would be larger but mine just looks like a large pulley not sure what has been done to this engine before I got it so I'm hoping something isn't missing.
Old 02-13-2009, 05:24 AM
NumberDummy
If the rubber cracks, the pulley walks away from the inner damper, so there will be a lip formed between the damper and the pulley.
Normally, these two pieces are flush with one another with just a fraction of an inch of the rubber exposed.
Ths harmonic balancer is a one piece assembly, so it was only available as such.
When being assembled, a rubber gasket is placed between the damper and the pulley, then the three pieces are pressed together forming a one piece assembly.
Old 02-13-2009, 05:27 AM
rsdjcarter's Avatar
rsdjcarter
I'll check it out. Is the rubber the only thing holding it together?
Thanks again Bill.
Old 02-13-2009, 05:43 AM
NumberDummy
Yes.
If the balancer begins to come apart, it should be replaced ASAP, otherwise...
Sooner or later...usually sooner, the pulley will completely separate from the damper, and end up in flaying away right into your radiator core with assorted belts and other bits 'n pieces.
I've seen the results of this on dozens of assorted cars/trucks over the years. It's not a pretty sight!
Old 02-13-2009, 06:01 AM
rsdjcarter's Avatar
rsdjcarter
That's not good! I'll deffinately check it out tomorrow, I've bee driving it almost every day now. Still getting a vibration under accel and decell but think I've narrowed it down to fowling a plug, gotta get these new heads on soon. I'm finally done with the VW project so the wife is happy and I can get to work on my truck, even got a new tool b ox out of the deal! Thanks.
olderford76
09-14-2015 07:38 AM
HD
1983 - 2012 Ranger & B-Series
09-28-2014 02:57 AM
svp_evo
12-08-2013 10:10 PM
timbersteel
12-03-2013 12:17 PM
MIKES 68 F100
24
09-12-2011 01:06 PM
Quick Reply: harmonic balancer....uh...do I have one?
