I have from squeaky bushings with I turn the wheel and go over speed bumps and stuff. I had my son turn the wheel for me and I was under the front and could see where the noise was coming from. It seems the control arm bushings move or give a bit when the suspension moves and they make noise. It just started last week. There are no fittings for grease. What can I do?
My 04 does the same thing,I cant pin-point where the noise is coming from.I have torn it apart and greased everything.the noise is amplifiyed thru every piece of the front end.the lube helped for a little while but if (I know this sounds crazy)it does not rain for a couple of weeks it starts again.The problem with greasing everything was it stoped it for a while but Im not sure what piece is actuly making the noise.If you fix it let us know.
