exhaust question
Old Oct 30, 2007 | 01:13 PM
2002f2507.3LPS's Avatar
2002f2507.3LPS
exhaust question
the stock system comes straight out the side behind the passenger side tire. iv seen some aftermarket companies have there pipes comming out at an angle rather then parrellel to the rear axle. id rather get aftermarket were its parrellel to the rear axle and not comming out at an angle. can anyone provide any company names or links to exhost system that come out perrallel and not at an angle.
thanks,
Old Oct 30, 2007 | 01:52 PM
wlihntr's Avatar
wlihntr
pretty much every after market diesel exhaust is 4 or 5 inches. from looking at my 4 inch system i dont see how they could make come out paralle with the rear tire (there is not enough room) unless they put some real tight funky bends in it right at the end
Old Oct 30, 2007 | 02:17 PM
TRICOMEDIC19's Avatar
TRICOMEDIC19
4" Exhaust???
I have a bone stock 7.3 SD. 4x4 6speed supercrew. I'm thinking about after market exhaust. What do you guys recommend, why and what did it do for you?
Old Oct 30, 2007 | 02:18 PM
ron's power stroke's Avatar
ron's power stroke
you mean like this?? (dont look at the dirt)..
Old Oct 30, 2007 | 02:20 PM
TRICOMEDIC19
ya man.. just like that... how do you like it? was all that money and work mainly for sound or did it improve anything? I'm all about improving the engines performance but not killing milleage.
Old Oct 30, 2007 | 02:31 PM
ron's power stroke
i got it from MKO over a year ago for $410 at my door..its a 4"DP 5" strait out to the 6"x18" chrome tip..i painted them with black stove paint to make them last..so far so good... any time you open up the exhaust makes it breath better..you can get all you need with the 4"... i went 5" for the deeper sound you get out of it..sounds mean from 2600 to 2800 RPM's
http://stores.ebay.com/MKO-DIESEL-PERFORMANCE
Old Oct 30, 2007 | 03:12 PM
2002f2507.3LPS
would u say they all sound the same? 4"MKO or magnaflow or MBRP?
iv seen the MBRP and others all cost about $580 for the 5"
MKO is selling 5" for $325.
there both alluminized steel.
is the price differents just brand name? or are there other reasons for the higher price?
Old Oct 30, 2007 | 03:27 PM
ron's power stroke
i would say they would sound the same as a strait pipe..
Old Oct 30, 2007 | 03:30 PM
2002f2507.3LPS
i eddited my last post, but i do like the look of the pipe commin out the side rather then at an angle. so it looks like MKO will be on Order when i look into an exhaust. 5" as well.
ron, it fit in there without hitting anything when u installed it?
Old Oct 30, 2007 | 03:33 PM
TRICOMEDIC19
Im thinking about going to that wicket wheel too.. Could you tell any difference afterwards?
Old Oct 30, 2007 | 03:41 PM
ron's power stroke
the DP was tight to where the head and valve cover come together..under the passenger seat is a heat shield with 2 long studs sticking down that need to be cut back for the 5" and I pushed my spare back and more to the driver side of the truck...I have a hide a ball goose neck under there and all it went in..hang every thing first to make sure nothing rubs...start at turbo working your way back tightening the clamps..the washers on the hanger may jingle at idle..I just put some form a gasket on the washers to stop that..
Old Oct 30, 2007 | 03:45 PM
ron's power stroke
i cant answer that..i went from the early 99 turbo to the stock 99.5 turbo..i did use the wicked wheel and have yet felt surge..i can also still get 27 to 28 lb boost with red line hooked...some guys say they feel a little faster spool up with the WW and thay have no surge..
Old Oct 30, 2007 | 03:47 PM
TRICOMEDIC19
Ive heard of SURGE a lot of times but I dont think I've ever noticed this on my truck?? What is it? How do you control it if you have it? lol.
Old Oct 30, 2007 | 05:09 PM
ron's power stroke
turbo surge sounds kinda like a pressure cooker on the stove. this is not good for the turbo...you need to let off the go pedle till it stops or drop a gear..to fix it from not getting surge you can do the WW or a ATS housing...
