Sponsored by: Auxito
tail light replacement
Old Oct 30, 2007 | 10:12 AM
Misfire's Avatar
Misfire
I feel a little stupid asking what is normally a simple task how to remove a tail light lense on a 97 f150 but after I removed the two bolts it feels hesitant to come lose. What else do I have to do to get it off so I can replace the bulb?
Old Oct 30, 2007 | 10:45 AM
swpipkin's Avatar
swpipkin
I just did mine on my 2005 F150 yesterday. Pull to the outside of the truck then straight back. There's little retaining ***** on the lens.
Old Oct 30, 2007 | 11:42 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Moved from 2009 F150.
Old Oct 30, 2007 | 12:24 PM
Misfire's Avatar
Misfire
Thanks for the encouragement, that's all it took. The retaining tabs were a bit stubborn but finally came loose.
Old Mar 21, 2008 | 08:44 PM
yinyang's Avatar
yinyang
Rear lense removal
Thank you so much for this discussion thread... made changing the turn signal bulb so very easy and especially the extra hint about pulling the cover over to the outside and then straight back... worked great!
RIKIL
Apr 18, 2014 10:30 AM
Ronmont
Electrical Systems/Wiring
Feb 22, 2014 07:03 AM
JimG1098
2004 - 2008 F150
Sep 17, 2013 07:45 PM
Strider27
Jun 3, 2013 08:37 AM
crawdad
2004 - 2008 F150
Apr 1, 2013 02:24 PM
