Kroil!! It Makes A Difference!!
Old Oct 29, 2007 | 08:21 PM
boots6868's Avatar
boots6868
Smile Kroil!! It Makes A Difference!!
About a month or so ago I went to changing my plugs on my 04 fx4 3 valve. I had read a wealth of information on this site and tsb's and followed them EXCEPT for using the recommended penetrating oil! I used PB blaster instead... Results one of 4 plugs broke in the head. And of course it was the back plug drivers side. So after finally getting the plug shell out. I ordered in the special removal tool @ 160.00 and I bought the penetrating they advised KROIL!!! boys this stuff works and i mean on anything you got rusted or siezed. This past weekend I got up the courage to change out the other 4 on the passenger side following all recommendations of course this time. Warm engine, break plug loose slightly 1/8 turn add Kroil just up to hex sides let set appx 15 minutes tighten back up and turn loose 1/2 turn ( should feel and hear distinct snapping sound. stop let set some more another 5 minutes tighten up should pop some more and loosen 3-4 pops or clicks stop again repeat untill snapps become as one then remove. yes it does take some time but you dont want the alternative. took me about 2 hours doddling around the shop then loosening but ALL 4 plugs came out fine. I got to hand it to Kroil and all the tsb's and you fellas on here for the results. sorry to be so long winded about this but I think this subject lots of patience!! I have done my friends truck this evening and took about 3 hours same success on a 04 5.4 3 valve. Good luck and Keep the faith! PS my 04 has 46,000 miles thanks
Old Oct 29, 2007 | 10:14 PM
MBBFord's Avatar
MBBFord
Hope that's all it takes to have a successful plug change.
The Kroil is some pretty good stuff. It's called the oil that creeps and for good reason.
Try Holding the hex head of a bolt with the threads pointing down, and spray the bottom tip of the thread with kroil, and you can actually watch the oil go straight up the bolt!
Old Oct 29, 2007 | 11:14 PM
ech0sh4y's Avatar
ech0sh4y
u had to change plugs at 46,000 miles? Should i be doing this? I thought it was 100,000 miles or so. Also where does a guy get this Kroil that creeps!?
Old Oct 30, 2007 | 11:11 AM
wolfe68's Avatar
wolfe68
that's some great news, nice job man.
Old Oct 30, 2007 | 11:43 AM
MBBFord's Avatar
MBBFord
Most stores don't carry it, but you can search kroil and it will give you their web site and you can buy it from them. I lucked out and found a hardware store in a near by town with it.
The plug change is suposed to be at 100,000 miles, but do the the plugs breaking in the head because of built up carbon, some people are trying to prevent them from breaking by changeing them before to much carbon has been built up.
I'm at 97,500 and it's getting closer and closer.
Old Oct 30, 2007 | 12:24 PM
sysman_rick's Avatar
sysman_rick
Post
www.kanolabs.com It's great stuff!
Old Oct 30, 2007 | 01:01 PM
DMAC66's Avatar
DMAC66
I realize you have probably read this from me before but I thought I would say that if you cannot find the Kroil (AeroKroil) without going on-line, you can substitute Sea Foam Deep Creep (available at Advance Auto and probably others). The key component is the gasoline base that penetrates and dissolves the carbon deposits. This is why liquid wrench and PB Blaster will not do the job.
DMAC
Old Oct 30, 2007 | 03:00 PM
1saxman's Avatar
1saxman
I actually like Kano's 'Sili-Kroil' better. I have been using Kano Labs products for thirty years. Everything they have does what it says it will.
Old Oct 30, 2007 | 06:45 PM
ohboy44's Avatar
ohboy44
Now you know why we spec Kroil in the TSB.
It flat out wotks.
Old Oct 30, 2007 | 09:54 PM
boots6868's Avatar
boots6868
Red face coat the spark plug too!
I also forgot to mention ... I did also use Permatex Nickle Anti Sieze on the plug shell going back in. Caution though they say not get any down on the sparking portion of the plug.
Old Oct 30, 2007 | 10:16 PM
MBBFord's Avatar
MBBFord
boots6868, I got a question for you.
I'm assuming that's the 8 oz bottle of the permatex, and you have plenty left....
Would you consider selling what you have left????
I really don't feel like giveing some store $15 shipping for a $20 product.
If you don't plan on useing it again, I'm in need of a spark plug change(2,500 miles left till), and I could use some.
Thanks in advance for any feed back.
DWinTX
2004 - 2008 F150
20
Jun 2, 2020 08:07 AM
Ted928
2004 - 2008 F150
Jul 1, 2016 12:19 PM
Beechkid
2004 - 2008 F150
40
Jun 22, 2016 09:26 PM
Gage2502
Dec 30, 2015 10:11 PM
thousand_mile_stare
2004 - 2008 F150
21
Nov 13, 2015 12:43 AM
