Sponsored by: Real Truck
Squeaky Belt
Old Oct 29, 2007 | 02:11 PM
tow2atm's Avatar
tow2atm
Question Squeaky Belt
I have a sqeaky belt in my 6.0 liter diesel. (39,000miles) My belt looks to be in good condition. Any suggestions? Should I try a silicone spray or is that just temporary? I was told to spray a rag with brake cleaner and wipe the belt down, but wont that harm the belt? I once had a gas Ford pick-up and Ford actually had a grease for there sqeaking belts.
I tryed the search link and didn't get to far.
Old Oct 29, 2007 | 03:04 PM
jim henderson's Avatar
jim henderson
The serpentine belts in my experience don't like belt dressings. Sprays like silicone and WD40 just hide the problem and make it worse over time. Belt dressing seems to work OK on V belts but it has been a long time since I had one of those.
With serpentines, it seems the problem is slippage on the shiney surfaces of the pulleys and idlers. What I do is clean the surfaces with alcohol or brake cleaner. I might roughup the surfaces with sand paper or steelwool.
If the belt is galzed it will squeal. You might be able to clean it with alcohol or maybe brake cleaner. You don't want to soak the belt in brake cleaner sine I think it will eat the rubber over time.
Good Luck,
Jim Henderson
Old Oct 29, 2007 | 03:08 PM
txharley's Avatar
txharley
I just got out of the shop with the same problem. Mine would only squeak when cold. Turned out it was the idler pulley. It was covered in the 100,000 mi warranty. The tech also threw on a new belt.
Old Oct 29, 2007 | 03:26 PM
blackhat620's Avatar
blackhat620
There is a TSB 05-13-16 for replacement of the water pump pulley that was defective and leads to damaged and broken belt.
http://www.ford-trucks.com/tsb/fullt...p?tsb=05-13-16
Take your truck in and have it diagnosed and repaired, you may want to print out the TSB and take it with you.
Belt dressing if it works at all will just mask the symptoms.
Ed in Maine
Jan 14, 2014 09:59 PM
fordinmudd
Apr 5, 2011 03:36 PM
omni
Oil & Lubrication
29
Sep 1, 2009 12:09 AM
stangman516
Dec 13, 2007 07:33 PM
BTHiii
1997 - 2003 F150
Jul 24, 2003 12:42 AM
