7.3L 89 Not running
Old Nov 4, 2007 | 11:35 AM
sglaine's Avatar
sglaine
Posting Legend
Originally Posted by meanv10
Went back and bypassed the fuel tanks, after i took off the bed and found which tanks was leaking, so it fired up after a few tries and then switched back to the tanks bleed the shredder valve and it ran like a fricken dream, the thing has sat in the woods for over two years, cant believe it, thanks for the help guys. but the power steering doesnt work. it was empty so i filled it and took it out for a spin came back and it was empty again and i didnt see any leaks any advise?
I'm glad it worked out for you..Great job..
Old Nov 4, 2007 | 08:21 PM
bigblock_drock's Avatar
bigblock_drock
Yes congrats on figuring it out
but there pretty much has to be a leak, just have to look harder. look around the resevoir, and follow all the lines
Old Nov 4, 2007 | 08:29 PM
starmilt's Avatar
starmilt
it is possible the whole system was empty when you drove it most wound up in gearbox and lines. even though it sat a couple years it had to leak out somewhere it will show up pretty quick.
Old Nov 5, 2007 | 04:34 PM
meanv10's Avatar
meanv10
Ya went back and filled it up 2 more times and now it works. the whole system must have been empty like you said. thanks for the advise.
Old Nov 13, 2007 | 03:41 PM
meanv10's Avatar
meanv10
How could i figure out the gear ratio in the axel? looked at the tag on the axel and all it was, was letters and numbers that didnt even resemble a ratio? thanks
Old Nov 13, 2007 | 03:47 PM
sglaine's Avatar
sglaine
Posting Legend
If you take the VIN # of the truck to the dealer they can tell you all you want to know about the truck
Old Nov 13, 2007 | 04:19 PM
starmilt's Avatar
starmilt
there is a vin decoder on this site somewhere. do you have a tach what rpms are you running at 65 most were either 4.10 or 3.55 the gvw on the tag is also different between the 2 ratios or you can jack it up turn wheel count turns on driveshaft and wheel.
Old Nov 13, 2007 | 08:59 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Bottom line of numbers on the tag will start with .10 or .55 or L10 or L55 in most trucks.
.10 or L 10 mean 4.10 and the L indicates limited slip.
.55 or L55 mean 3.55 and the L indicates limited slip again.
Nicknaz
19
Feb 6, 2016 04:54 PM
Nitro Nick
Oct 18, 2013 10:11 PM
zigelbaum
Feb 25, 2013 05:20 PM
nick7.3
Feb 15, 2012 04:54 PM
cHiLi 11
6.4L Power Stroke Diesel
16
Aug 28, 2008 02:45 PM
