headlight issue with 79'
Old Oct 29, 2007 | 01:43 PM
Doug J's Avatar
Doug J
I have a 79 F150 that I am restoring. Just before I started restoring I had a problem with the headlights going on and off. I have replaced the high/low switch and even bypassed the light switch in the dash. Any thoughts as to where to go next cause I am putting it back together now almost ready for the paint.
Old Oct 29, 2007 | 01:46 PM
Mil1ion's Avatar
Mil1ion
Do the headlight relay upgrade while you have everything apart.
http://www.northwestvintagebroncos.c...headlight1.htm
https://www.ford-trucks.com/article/...ay_System.html
Ford ran everything through the headlight switch with circuit breaker protection.
Doing this caused the H/L switch and dimmer switch to fail.
The relay system is the way to go.
The headlights will also be brighter.
Old Oct 29, 2007 | 01:48 PM
Doug J's Avatar
Doug J
Will do thanks
backacheacres
1947 and Older Ford Trucks
Jun 7, 2013 08:42 AM
makingaZJ
Apr 5, 2011 09:13 AM
Blade79
Maryland Chapter
13
Jul 18, 2010 07:39 PM
90fordford
Dec 15, 2005 02:26 PM
