help!!!!!!! wont start
Old Oct 29, 2007 | 11:48 AM
tcm368's Avatar
tcm368
ok well i went out to the truck right now and tested the voltage to the relay. i got 12 volts to the hot side (the one that has the rubber cover over it i assume) and then i turned the key and let the WTS light go and and tested for voltage on the other side of the relay and got nothing so i assume that the relay is bad. im guessing i should get 12 volts on the other sides since the relay should then be open correct?
Old Oct 29, 2007 | 12:52 PM
billfishnut's Avatar
billfishnut
Originally Posted by nlemerise
The WTS light is in no way connected to the GPR. The WTS light could be on and the GPR could be off OR the WTS light can be off and the GPR could be on. In other words, the WTS light is not one of Ford's better ideas. That is why they should have put the WTS light in to the cold side of the GPR...then you know when it is on and you know when it is off.
Totally aware that the two are not tied together. They do however come on at approximately the same time and, as I stated, the relay continues to cycle after the WTS light goes off.
Old Oct 29, 2007 | 01:05 PM
billfishnut
Based on what you said, the glow plug relay is not closing. This is the problem but before you buy a new relay, make sure the relay is getting voltage to close.
Check for voltage on the small wire (thinking its the pink one). It energizes to close the relay. It is possible to have a good relay that is just not energizing.
Old Oct 29, 2007 | 02:01 PM
tcm368's Avatar
tcm368
what could the possible voltage be coming out of the pink wire? and if there is not any voltage coming from that what am i looking at?
Old Oct 29, 2007 | 05:30 PM
mxfam4x4's Avatar
mxfam4x4
the switch wire should be 12 volts as well
Old Oct 30, 2007 | 12:01 PM
billfishnut
Talking
I would have to look at the wiring diagrams but more than likely its the relay.
Let me know if you don't have 12 V on the pink wire and we can go from there.
Since I am a day late, I'll bet you already got the relay anyhow.
Old Oct 30, 2007 | 12:12 PM
tcm368's Avatar
tcm368
yeah i went and tried to start the truck this morning didn't start on the first crank so got out an old 10mm wrench popped the hood and just crossed the relay terminals with the wrench and the relay started clicking here and there went back inside and truck fired right up. on the way to work stopped at the international dealer on the way to work and got a new relay. so got a quick project after work. One of the techs at the International Dealer told me tho that unpluging the connector that goes to that fuel warmer on the passenger side also helps a little with the cold start up. that sounded funny to me cause i thought that would help but he said it seems to be the otherway around. He worked in the BIG DIG project here in Boston as a deisel tech and all his company had at the time was 7.3 and if you are from around here you know the amount of trucks that worked in that 15 year project. and he swore by it, to unplug that connector. anyone heard of that helping them
Old Oct 30, 2007 | 01:29 PM
billfishnut
Might have to try that out myself
Old Oct 30, 2007 | 01:48 PM
rbaker6336's Avatar
rbaker6336
ok guess I missed something,where is the fuel warmer wire to unplug
Old Oct 30, 2007 | 02:01 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
on the back of your fuel filter bowl, on the bottom back, next to the drain valve.
Old Oct 30, 2007 | 02:10 PM
tcm368's Avatar
tcm368
im not to sure what exactly it is he said there is a bowl that fills with fuel and there is a warmer i gues that turns on when you key the key to let the glow plugs warm up. i think im going to have to go back and have him show me cause im still scratching my head after i spent my lunch break tryin to figure it out
Old Oct 30, 2007 | 02:32 PM
tcm368's Avatar
tcm368
ok looking through a manual i have and getting off the phone with that tech the fuel warmer that he was reffering to is at the bottom of the fuel filter bowl. but i still don't see how this is going to help in a cold morning start up?
Old Oct 30, 2007 | 02:47 PM
  #28
PETE'S_6.0PSD
i dont think this has anything to do with cold starts. if its not starting, maybe yes cause those elements take out a fuse when go bad, and will not start.
so by unpluging it will allow you to fire it up, after you replace PCM fuse.
Old Oct 30, 2007 | 02:51 PM
  #29
tcm368's Avatar
tcm368
got you that makes sense now. i will be leaving that alone i don't see how you would benifit in any way by unpluging that. unless i have the blown fuse issue from that element goign out.
Thanks Pete for the info
Old Oct 30, 2007 | 02:54 PM
  #30
PETE'S_6.0PSD
you welcome.
RedDevil460
Sep 20, 2013 07:52 PM
Pocket
57
Sep 22, 2010 11:38 AM
boggerted
Dec 26, 2008 09:27 AM
azcowboy
49
Sep 4, 2007 11:36 PM
HTRDLNCN
21
Nov 22, 2005 11:44 PM
