292 Y-block Forged Internals
Old Oct 29, 2007 | 06:58 AM
matt2491's Avatar
matt2491
What years did they make forged internals for the y-block? And exactly which parts were forged (crank, rods, piston...)?
I've been working on a '64 F100 with a C2AE casting # on the 292 block and I think I read somewhere that this block had forged parts.
Any help appreciated. Thanks/
Old Oct 29, 2007 | 11:30 AM
airharley's Avatar
airharley
You might be better off the check in the Y-Block forum. They have a lot of knowledgable people there.
Old Oct 29, 2007 | 11:35 AM
312's Avatar
312
61 to 64 in big trucks only.crank and pistons.
Old Oct 29, 2007 | 02:02 PM
matt2491's Avatar
matt2491
But not the rods?
_____
And "big trucks" you mean like the F600 or something?
Old Oct 29, 2007 | 11:22 PM
mrcman58's Avatar
mrcman58
Smile Y block
the C2AE block is probally the best block to get aside of the ECZ block, if the motor is out and you have access to look at the flywheel end of the crank shaft, a quick way to identify the crank type is by its flywheel end design.there is several types. i dont know how to post a pic for you, or i would send a diagram with the different varietys. hope something here helps
Old Oct 29, 2007 | 11:24 PM
mrcman58's Avatar
mrcman58
Smile welcome to FTE
also i forgot to mention , welcome to FTE,
Old Oct 30, 2007 | 06:58 AM
matt2491's Avatar
matt2491
Here's a pic of the flywheel after I removed the clutch:
Through bellhousing: http://picasaweb.google.com/reyalsbe...85935964062738
View of the flywheel from underneath:
http://picasaweb.google.com/reyalsbe...86056223147058
Can you identify it?
