95 F250- problem with trailer plug
Old Oct 28, 2007 | 07:54 PM
superduty4x4's Avatar
superduty4x4
Back in August, we were getting ready to tow our 28ft. camp trailer back home and were having problems with the lights not working properly. The truck and trailerhave been sitting since. Fast forward to now- I'm toying with selling the truck and I'd like to get the trailer wiring thing fixed (especially if I end up keeping the truck for a while). I don't have any power to the left turn signal or the running lights- I've tried disconnecting the two plugs that go to the trailer plug at the bumper and cleaning all the contacts with contact cleaner, but no luck. Does anyone know if the wires for the trailer plug run clear up to the front of the truck somewhere? If so, where do they start up front so I can go there and work my way back. I hate wiring issues...
Old Oct 29, 2007 | 06:03 AM
92F150Flare's Avatar
92F150Flare
If it's a factory trailer plug like mine......It appears to only be wired in along side the fuel tank. I haven't traced but when I tied it up out of the way I saw the wires were going into an oversized area wrapped for protection. I don't use mine so I tied it back. If your's is aftermarket.......nothing you can do but trace til you find the connections.
I couldn't agree more on hating wiring issues!!
Good Luck
Bob
Old Oct 29, 2007 | 03:40 PM
subford's Avatar
subford
Yes they go all the way to the relay/fuse box under the hood.
Left turn is fuse "G" and the marker lights is fuse "D".
Check for a bad fuse or relay.
Old Oct 29, 2007 | 09:01 PM
superduty4x4
Thank you subford, that's EXACTLY what I was looking for!
Old Nov 4, 2007 | 07:07 PM
superduty4x4
subford I owe you a beer! I had 3 blown fuses in the under-hood power distribution center. Replaced them and voila... full power to the trailer plug. Thanks for the help, you saved me a lot of time!
Old Nov 4, 2007 | 09:29 PM
msb71's Avatar
msb71
Had the same thing happen on my rig, didn't know it even had a fuse/relay box under there. glad to hear you found the problem.
Mike
Baicolt
Apr 22, 2015 04:18 PM
sowaxeman
Jul 31, 2014 04:15 PM
Tifford
Electrical Systems/Wiring
Sep 14, 2013 05:54 PM
jeeplj8
Nov 28, 2012 09:24 AM
Glockem45
All Things Towing
41
Nov 12, 2010 05:56 PM
