Sponsored by: Innova
Alternator for subs
Old Oct 28, 2007 | 06:13 PM
pdqtimetrialer's Avatar
pdqtimetrialer
Alternator for subs
I just replaced the alternator on my 99 Expy because the bearings were bad and it had no output.
With 101k, I'm not surprised the bearings went bad, I'm wondering if it may have burned out because of an amp and subwoofer my stepson recently installed. He's added a Rockford Fosgate P4004 and MTX Thunder speakers that have a max output of 1500 watts. Since it is only a 130 amp alternator (there wasn't any bigger available) and rated max at only 1400 Watts, I'm concerned this one is going to burn up to. I looked at the data on the alternator and the max output occurs at max engine rpm. Idling or normal driving its only putting out about 1000 Watts.
My question is, does he need to install something else to help power the amp and subwoofer, or can the Expy power the system as factory built.
Old Oct 28, 2007 | 07:50 PM
Beerstalker's Avatar
Beerstalker
The amp is only rated at 400watts RMS. That is only about a 30 amp draw and I don't think it is going to cause any problems.
Old Nov 12, 2007 | 09:43 PM
GnFnRs's Avatar
GnFnRs
i had the stock alt. 130 amps in my last two trucks. each running 4 batteries and 8700 watts..after three years on the f150 with v6 it was still working fine with over 119,000 miles..the expedition had the same system in it and had 89,000 with no problems. now i am scared of the alt on my 03 6.0lpsd.
Old Nov 13, 2007 | 07:58 AM
fordboy_52's Avatar
fordboy_52
most amps pull less current than headlights. some do, but i doubt yours did
Matt
Old Nov 13, 2007 | 04:46 PM
GnFnRs's Avatar
GnFnRs
yea the amps said to use a 150 amp fuse at the battery per amp..and i had two of them. buti only had a single 125 amp fuse on it for all those years.
Old Nov 13, 2007 | 08:51 PM
bla1879's Avatar
bla1879
well if your worried throw in a capacitor, so you got some room to play and dont need to worry
