Front Tires Toe Out
Old Oct 27, 2007 | 10:42 PM
GrimOne's Avatar
GrimOne
Front Tires Toe Out
I appear to be having a problem with the front end on my truck a 1996 F-250 4x4... I think.. My front tires (sitting on level ground) appear like this from the front /----\. I've seen this on more Ford pickup as well. From behind the wheel it doesn't feel like I have any problems aside from a slight pull to the left. But I can't help but think that something, somewhere is off in the front suspension. Does anyone have any ideas simple to complicated as to the cause of this problem and possibly how to fix it? Thank you in advance for the help.
Old Oct 27, 2007 | 10:54 PM
radialarm's Avatar
radialarm
Take it to a front end shop if it bothers you. Don't do it yourself unless you know what your doing.
Old Oct 28, 2007 | 06:12 PM
mhg's Avatar
mhg
weak springs and /or worn ball joints cause this
this is a negative camber problem
Old Oct 29, 2007 | 09:01 AM
Conanski's Avatar
Conanski
You front springs are weak.. replace them.
Old Mar 10, 2008 | 01:54 PM
jwhitehead's Avatar
jwhitehead
Old Mar 10, 2008 | 01:55 PM
jwhitehead's Avatar
jwhitehead
It's normal on an IDS front end... it's really exaggerated if you back up before you park. You can take it to a front-end shop and they can align it and take your money, but the first time you use reverse it'll do the same thing again.
dfromfresno
May 30, 2012 04:05 AM
maldbwmjr
Mar 1, 2008 08:32 PM
begger
Aug 26, 2007 07:45 AM
RockyMtnRanger
Aug 18, 2007 02:08 PM
Rob04
Nov 2, 2006 01:46 PM
