Sponsored by: Real Truck
Grabby clutch!
Old Oct 27, 2007 | 06:29 PM
dash9w's Avatar
dash9w
Question Grabby clutch!
Hi All, I'm fairly new to this great forum. Here's my problem: About 3 months ago I bought an '06 F250 SD,5.4l,6 speed manual,RWD with at the time 33,000+ miles on it. I find that the shifting itself seems rather tight and in damp weather the clutch feels awfully "grabby"(near the top) when engaging and if I'm not careful I will stall the engine when starting in gear #2 which I assume is the normal "starting" gear. Rear end ratio is 3.73 Any suggestions/idea will be greatly appreciated!
As an aside has anyone tried installing one of those "short throw"
shift replacements on their rig?
Old Oct 27, 2007 | 07:27 PM
redford's Avatar
redford
FTE Leadership Emeritus
It is still under warranty, so you might take it in and complain to the dealer.
Old Oct 28, 2007 | 12:52 AM
deere81's Avatar
deere81
I installed a short throw shifter on my '05 F-250.
Old Oct 28, 2007 | 09:33 AM
armymark's Avatar
armymark
It shouldn't stall in any gear with the clutch engaged while starting, and damp weather shouldn't have any affect either. Take that baby in and have them look at it.
Old Oct 28, 2007 | 12:00 PM
aldridgec's Avatar
aldridgec
Sounds like the disc could have some broken fingers on the diaphram, oil contamination or the hydrauilcs have air/moisture contamination.
Old Oct 28, 2007 | 05:47 PM
dash9w's Avatar
dash9w
Grabby clutch
Thanks guys. I will take it in and see what the dealer has to say about it.
Old Oct 28, 2007 | 07:12 PM
redford's Avatar
redford
Oil contamination would be my guess.
