Somebody please help me
Old Oct 27, 2007 | 05:35 PM
Smokey1's Avatar
Smokey1
Ok, truck is an 03 f350 with 162k kms. Had issues with it running rough, and stalling, i've replaced the fuel pump, and a leaking ICP sensor, neither have fixed the problem. Truck works fine under 100kms/hr and when not under much load, but if i give it alot of gas, or try to go over 100k/hr, when i slow down it pours out black smoke and then stalls and will not start. If i let it cool down for 10 minutes it starts everytime. From what i've researched this sounds like an HPOP problem, but is there a way that i can troubleshoot this at home? Also the truck is due for an oil change, and i run 15w40 in it, from my research i've also found that the low pressure oil has to be in good condition and such, is there any chance that this could be causing my issues?
Old Oct 27, 2007 | 05:37 PM
Smokey1's Avatar
Smokey1
Also to note, its emitting a whining noise, and i can't tell where it's coming from.
n2ojoe
Dec 31, 2010 05:24 PM
Culvert
Nov 25, 2010 08:22 PM
Culvert
Sep 7, 2009 03:59 PM
ranklore
2004 - 2008 F150
18
Mar 12, 2009 06:43 PM
eddiefan
Aerostar
Feb 25, 2004 05:52 PM
