max ft/lbs
Old Nov 15, 2002 | 09:02 PM
6 cyl boy's Avatar
6 cyl boy
max ft/lbs
Hello does anyone have any sugestions on how to increse low end torque
for a 72 300 HD engine. I am thinking in terms of a N/A set-up rather than forced induction. A 390 CFM holly on a DP offenhauser a higher lift cam (.500 in 260dur) and duel into 2.5 inch single exhaust is what I had in mind. But I'm interested to see if y'all have any better sugestions. Just remember I want lots of ft/lbs and I dont care about rpm's.
thanks
Joe
Old Nov 15, 2002 | 09:38 PM
heathdaily's Avatar
heathdaily
max ft/lbs
If you're willing to dig into the engine, replace the pistons. Those HD motors had really deep dish pistons for super low compression.
Old Nov 15, 2002 | 09:46 PM
6 cyl boy's Avatar
6 cyl boy
max ft/lbs
What about a 240 head? Bolt on or no? Does anyone make pop-ups for the 300? I would be very interested to know since I am just starting to research this.
thanks
Old Nov 15, 2002 | 11:19 PM
Ford_Six's Avatar
Ford_Six
max ft/lbs
I have what your engine could be- It's an HD lower end, with a forged crank, pistons for an F-150, and a ported&polished 240 head. This all breaths through an Offenhauser intake, and dual EFI exhaust manifolds. I really couldn't tell you what pistons to use, as mine was assembled when I got it.
Jared
Old Nov 16, 2002 | 03:11 PM
3006ROCKS's Avatar
3006ROCKS
max ft/lbs
I got this off of a site:
"So what's available for the 240/300ci six from Clifford? Plenty! Five different manifolds--two fours, three twos, one four, one two, and two twos. Cast-aluminum valve covers. Custom-forged pistons. Mallory ignition. High-performance oil and water pumps. Even forged crankshafts. Ultimately, you can achieve 600 hp and 7,000 rpm with a 300ci Ford six. Just imagine the possibilities in your sleeper street car."
Check out this site:
http://www.octm.com/dane/index57.htm
Its at the bottom of the page.
Garrett
Old Nov 16, 2002 | 11:14 PM
knocturnal's Avatar
knocturnal
max ft/lbs
