Starter Not Disengaging?
Old Oct 27, 2007 | 12:23 AM
Red94XL's Avatar
Red94XL
Exclamation Starter Not Disengaging?
I have just bought a 94 F-150 XL Automatic with the 4.9L I-6. It needs help. The Truck's starter dosent disengage. It just keeps spinning until the engine dies out or gets turned off. The old starter fried just put a new one in and same thing. Any ideas???
<!-- / message -->
Old Oct 27, 2007 | 12:47 AM
87f1504x42001's Avatar
87f1504x42001
my truck will occasionally hang up, and i have to choke it down by holding the brake in and letting the clutch out. then start it right back and its fine.
Old Oct 27, 2007 | 01:21 AM
Skandocious's Avatar
Skandocious
I'm almost sure this is your starter solenoid... Not much else that can cause this. Go down to your local auto parts store, they should have them for real cheap.
Old Oct 27, 2007 | 03:23 AM
dave2's Avatar
dave2
solenoid on the fender by the battery. That's my problem anyway. Does it every so often and I whack it with a wrench or something. Meanwhile, it's so afraid of the whack that it stops when I pull the hood release. I've got a new one, just misplaced it.
Good Luck,
Dave
Old Oct 27, 2007 | 03:41 AM
ccecilm2's Avatar
ccecilm2
I agree with a bad starter solenoid problem. Been there 2 times on my old '84 . They are pretty cheap and very easy to replace.
Old Nov 10, 2011 | 05:55 AM
jazz1's Avatar
jazz1
Well I had starter engage while I was driving and took a while to get it to stop so I replaced solenoid..This morning the starter stuck when I started the truck,,gave my new solenoid a whack..Could it be the starter?
Old Nov 10, 2011 | 09:14 AM
deljac's Avatar
deljac
i had the same problem and it was running for 5 miles before i realized it and it burnt up my starter
Old Nov 10, 2011 | 10:28 AM
Phy's Avatar
Phy
Sounds like the starter relay on the inner fender.
Just for clarification, the starter solenoid is mounted on the starter, and is what pushes the starter drive gear into engagement with the flywheel ring gear. The starter relay is whats mounted on the inner fender by the battery. I know, the relay is commonly called a solenoid, even by parts suppliers, and that's partially correct, as a relay is an electrically-operated switch that uses a solenoid inside to close the contacts...
In any event, since the starter was replaced with a new one, most likely the relay is sticking on.
Old Dec 4, 2011 | 03:59 AM
rocks460's Avatar
rocks460
Its the starter solenoid switch located on the passenger inner fender
Had the same problem on my 90 f250
really easy to replace costs like 20 bucks
next time it gets stuck get out pop the hood and smack the solenoid switch with your hand or a wrench the starter should disengage.
m.collins
36
Apr 16, 2015 11:42 AM
Speedman_1026
Apr 13, 2014 04:40 PM
heavy_d
16
Mar 21, 2014 12:21 AM
86bullnose95
Oct 21, 2013 09:35 PM
Vern Anderson
Nov 4, 2004 02:14 AM
