Sponsored by: Real Truck
tranny temps
Old Nov 17, 2007 | 08:42 PM
Rubidon's Avatar
Rubidon
Thumbs up tranny temp
So if my sender is a brass block with a rubber hose on each end and the electrical connection in the middle,kind of like a tee, the electrical fitting should unscrew and then I can screw it into the pressure port?
Old Nov 17, 2007 | 09:07 PM
dfuser's Avatar
dfuser
You got it.
Old Nov 13, 2008 | 10:42 AM
Rubidon's Avatar
Rubidon
Thanks people,I finally got the time to relocate the sender to the pressure port and it is running between 150 and 180 degrees. Someone cut the hoses to the tranny cooler to install the sending unit. I am going to blow compressed air through the cooler to make sure it is not plugged and hook it back up.
264WSM
Jan 28, 2012 02:06 PM
klr650goldwing
Modular V10 (6.8l)
Dec 9, 2011 06:34 PM
comet
Oct 13, 2008 10:29 AM
vls
May 24, 2008 08:48 PM
tawd77
Feb 5, 2007 08:17 PM
