1978 - 1996 Big Bronco
Battery drains..
Old Oct 26, 2007 | 04:24 PM
dj250's Avatar
dj250
Battery drains..
Hey guys,
Got a problem with a 91' Bronco I bought not too long ago. The battery drains overnight, or basically over 10 hours. I can't figure it out so I've installed a battery switch in the grille untill I know what's wrong with it. No shorts, no lights stay on, ingnition shuts off and works properly. I tested the voltage draw between the battery and the ground, pulled all the fuses and relays inside the cab one by one and it always seemed to be drawing power. It went from 12.8 volts to like 11.7 in the hour time I was messing with it. Anyone have an idea?
Also, electronic 4WD seems to engage whenever it wants when I try to engage it. Like 1 out of 3 times pressing the button. And it also stayed engaged one time after I turned it off and the 4x4 light was out. Shut it off for a day and it was back into 2wd.
The above problem is more important though.
Old Oct 27, 2007 | 12:26 PM
blue beast's Avatar
blue beast
Smack your solenoid if it isn't disengaging all the way, It could draw down the battery
does it have problems starting ever. Since the fuses didn't work
did you try the fusible links. Pull them off and see if the draw stops. If you have a
bad cell in the battery it will drain the battery too!!
Old Oct 27, 2007 | 03:59 PM
helirich's Avatar
helirich
Sometimes if the battery is dirty, it can drain down. I guess the grime is somewhat conductive. I wouldnt think it would go down that quick though.
12valveEx
Aug 16, 2013 08:24 PM
apollo3519
3.8 & 4.2L V6
Sep 18, 2008 07:19 PM
erbenson
Jul 24, 2008 05:25 AM
palmer1998
1997 - 2003 F150
Dec 16, 2006 08:55 AM
nomar145
1983 - 2012 Ranger & B-Series
Aug 15, 2003 07:26 PM
