06 f150 problem, need opinions
Old Oct 26, 2007 | 03:16 PM
yellow_lab's Avatar
yellow_lab
this is the 3rd time i have taken my truck in for service for the same issue. when turning the key to start the truck, it chokes. It sounds like a diesel and then dies. I turn the key again and it starts.
yesterday, it took about 12 seconds to even turn over. (first time that happened).
any idea what could be going on?<!-- / message -->
Old Oct 26, 2007 | 05:18 PM
NASSTY's Avatar
NASSTY
If they can't fix it this time take it to a different dealer.
Old Oct 27, 2007 | 01:45 AM
rootdenied's Avatar
rootdenied
leaky injector maybe? Don't think the 06's would have that problem though.
Old Oct 27, 2007 | 08:35 AM
powderburn2's Avatar
powderburn2
you aren't pushing the gas pedal before you turn the key are you? I am sure you probably aren't. I always turn my key to the on position for a second or two until the fuel pump has had time to pressure up. Mine will kind of diesel and die if I don't.
Old Oct 27, 2007 | 09:44 AM
DaMole's Avatar
DaMole
<!-- / message --> any idea what could be going on?
How many miles are on the truck?
Old Oct 27, 2007 | 06:41 PM
Sarge261's Avatar
Sarge261
I had that problem on mine and it would run like crap all the time. They found that the cam in the right head was wiped out. They replaced the cam and lifters all gaskets and gave me an extended warranty. I would take it in and have it checked. You shouldnt have to prime the fuel system. You may have a bad pump... they will bleed down causing an extended crank.
Good Luck !!
Sarge
Old Oct 27, 2007 | 07:55 PM
Wilber15's Avatar
Wilber15
Many of the 5.4L 3V engines over the past few years have the injector leaking/sticking problem. I did one today and another guy in the shop had an 06' f-150 with a #2 leaking injector. The IDS wouldn't even perform the injector flow test it would leak down so fast. Are you cranking for 12 seconds before it starts, or is it 12 seconds before it even starts to crank?
Old Oct 27, 2007 | 10:12 PM
04 FX4 Lineman's Avatar
04 FX4 Lineman
Wilber: Need a bit of info can u tell me after I change my oil on first start up if I hold the throttle to the floor will it keep the engine from starting until the oil filter is filled and then I can take my foot of and start engine without knocking until filter is full??? I hate that sound first time until pressure comes up I have heard u can do this need info from someone who works on them, I have a 04 5.4 3V Thanx
Old Oct 27, 2007 | 10:19 PM
DearbornDerek's Avatar
DearbornDerek
Have you tried putting oil in the filter before you install it? Thats what the oil change guys did with my truck and I never had any "sounds" at startup. Just an idea.
Old Oct 27, 2007 | 10:30 PM
04 FX4 Lineman
I have tried that but I can only get in maybe half full without it running out when I go to put it up in place?? When u get my 6.2 ready maybe it will be different, have u seen one yet by chance and don't try to trick me??????????? L8R
Old Oct 29, 2007 | 07:54 AM
Sarge261's Avatar
Sarge261
Yes,
If you hold down the throlltle pedal to the floor it will prevent the truck from starting. I carnk mine until the oil light goes out. I will crank for like 3 sec. and then stop and then for 3 sec... so on until the light goes out. I do put about 1/2 qt. in it before I put the filter on too.
Sarge
Old Oct 29, 2007 | 01:25 PM
FHBrian's Avatar
FHBrian
I have noticed a similar thing the last few weeks. When I first turn the key in the times it doesn't start my mileage thing (I have a Lariat with the display) says low oil pressure for a second. Then today while leaving for lunch it did the same thing but it took three or four tries to get it to start and the low oil pressure was on till it started. After it start gauge reads fine and it runs great. 06 w/5.4 and 27,000 miles. Does this sound like the same thing. I guess I should take it into the shop?
Old Oct 29, 2007 | 03:27 PM
04 FX4 Lineman
Smile
Originally Posted by Sarge261
Yes,
Sarge
Thanx Sarge I will give that a try next oil change have heard of it but have never tried it
Old Oct 30, 2007 | 07:13 AM
yellow_lab's Avatar
yellow_lab
i never depress the gas pedal before starting. the truck has 28k miles. Been doing this since i bought it. the problem comes and goes.
Steve in NC
Nov 4, 2014 09:47 PM
jayro88
Apr 18, 2014 06:43 AM
Blaster696969
May 14, 2012 05:32 PM
gb'sfx4
Nov 17, 2008 07:12 PM
dfwrider
Dec 4, 2007 05:15 PM
