power steering hose leaking
Old Oct 26, 2007 | 01:37 PM
kmulholl's Avatar
kmulholl
77 f250 4x4, the return hose for steering is leaking where it zig-zags on the cross-member of the frame. the hose is steel, i am considering just cutting the tubing and bypassing that section of tube. anyone think this is a bis mistake (will pump over heat) . use the truck daily (local only, maybe 20 miles day). would be 5 minute fix. on a different note, i had a fuel starving situation with my 2150 motorcraft. would be driving fine, then felt like it was starving. i'm pretty sure i found the problem, the float was shifting slightly, allowing fuel by (it was actually flooding) , fuel was coming out the vent (bowl). the spring that holds the float in position was not in the grooves on the shaft thing. hope this helps someone else.
Old Oct 26, 2007 | 02:11 PM
tractoman's Avatar
tractoman
Are you sure it's the hard line leaking, and not just running down and dripping off? Maybe tighten or replace the clamps if they are the non tightenable cinch type. When my PS pump was leaking it looked like that too but it was the pump.
Old Oct 26, 2007 | 02:37 PM
kmulholl's Avatar
kmulholl
mike, thanks for the reply, it's for sure the steel. probably been leaking a little bit for a while. now it's really leaking alot. maybe hit with a stone or something.
Old Oct 26, 2007 | 02:58 PM
tractoman's Avatar
tractoman
You could always cut it, and slide rubber PS hose over the metel ends and put a couple clamps back on there. Sounds cheesy I know but I'm not to sure how hot the PS gets on the return so I wouldn't just remove it. If it's near an end, cut off a small section.
Old Oct 26, 2007 | 03:10 PM
kmulholl's Avatar
kmulholl
i was gonna cut it close to the pump, and swing the rubber hose that's already there over. your idea is better. leave the line , cover the leaking area and clamp it. thanks mike
Old Oct 26, 2007 | 04:03 PM
Matts72's Avatar
Matts72
2wds don't have that cooler assembly, unless you are offroading a lot I wouldn't worry about it too much if you decide to remove the cooler. If you have the proper tools, cut out the offending steel section, flare each end and slip a piece of power steering hose, PS hose is different than fuel hose it is much thicker and rated to 400 PSI.
Old Oct 26, 2007 | 04:54 PM
kmulholl's Avatar
kmulholl
thanks matts72, that info makes me feel better about leavinhg out the zig-zaggy part- i'll get under there in the morning and make a decision.
Old Oct 26, 2007 | 05:15 PM
Mil1ion's Avatar
Mil1ion
Actually Matt,
I am in the process of removing that cooling line from my 75 4x2 parts truck.
So, yes it was installed on 4x2's.
Old Oct 26, 2007 | 05:38 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D6TZ-3A713-E .. Power Steering Return Hose ~ Used On:
1973/77 F100/350 2WD
1976/77 F250 4WD before production date 4/1/77
D7TZ-3A713-F .. P/S Return Hose
1977 F250 4WD with integral P/S after production date 4/1/77
Old Oct 26, 2007 | 07:35 PM
Matts72's Avatar
Matts72
I completely forgot that I added power steering to my 68 2wd... but again, I wouldn't worry too much about it... heat wasn't the major failure for Ford pumps.
Old Oct 26, 2007 | 07:44 PM
75F350's Avatar
75F350
Everyne has mentioned a couple of ways to get creative and repair a 30 yr. old hose, but my local parts house has them in stock and sells them for about $28.00 (US).
Wouldn't a new hose be the best bet all around, I mean for the little investment, if it lasted only 15 years, you would be way ahead of the game, since the potential for failure is greater on the old hose.
Murphey rides in my truck, and that repaired hose would break down at the worst possible time. Might put your mind at ease to jusr get a new one.
I realize it is only a return line, and under low pressure.
Old Oct 26, 2007 | 07:48 PM
Mil1ion's Avatar
Mil1ion
Part of that hose is all that the steel line from the factory.
I suppose a new clamp could be put on it.
Old Oct 26, 2007 | 07:56 PM
kmulholl's Avatar
kmulholl
ya, good advice, i'll see if my store has them. i doubt it, but just maybe- fingers crossed .
Old Oct 26, 2007 | 07:59 PM
NumberDummy
Make sure that the hose you get is for a 1977 or earlier. The 1978/79 hose has a different fitting with an O ring on it, and it will not work on 1977 and earlier models. Power steering pumps changed in 1978.
P/S return hoses sold by autoparts stores may not have the cooling grid on it.
Old Oct 26, 2007 | 08:19 PM
Matts72's Avatar
Matts72
Bill is right, the return hose that the parts store sells is just hose, not the steel.
