vibrations
Old Oct 26, 2007 | 11:34 AM
mperry29's Avatar
mperry29
vibrations
trying to look thru all posts, but too many possibilities..anyway, here goes.
I replaced U joints in 97 explorer...after that bad vibration. Went to the junk yard and got a used drive shaft and put in, vibration went away. I just replaced my shocks all around and now I have a vibration again. It seems whenever I thighten things up, I get a vibration. 97 explorer, 178K miles. I have new front hubs, lower ball joints. Could it be the upper control arms? It just seems strange that replacing u joints or shocks would vibration. Any suggestions?
Old Oct 26, 2007 | 11:46 AM
97 Mountain Man's Avatar
97 Mountain Man
When does it vibrate? All the time? While turning? Low speeds? High speeds?
The more info you can give the easier and better it will be to diognose.
Old Oct 26, 2007 | 01:38 PM
mperry29's Avatar
mperry29
sorry, I left that out. It gets really bad between 65 and 70. If you really pay attention it is there a little at a low speed. Between 65 and 70 the center console vibrates to the point where I lean on it to stop the noise. The steering wheel has some vibration in it as well. It is rather hard to pin point if it is in the suspension or drive train. If you are on the back roads going 40 you would never suspect there was a problem
Old Oct 26, 2007 | 03:03 PM
97 Mountain Man
Have you had the balance on your tires checked? It could be that. It could also be a cupped tire or tread seperation.
Old Oct 26, 2007 | 05:47 PM
steve(ill)'s Avatar
steve(ill)
most vibration problems are tire related.
Old Oct 27, 2007 | 03:34 AM
ccecilm2's Avatar
ccecilm2
I had the same vibration problem on my '97 MM. All it needed was tire rebalancing.
Old Oct 27, 2007 | 01:29 PM
mperry29's Avatar
mperry29
I guess we will try that. Rotating the tires as we speak. I will let you all know. Thanks for the suggestions
Old Oct 29, 2007 | 08:20 AM
mperry29's Avatar
mperry29
Solved
We rotated the tires, the vibration is much better. I guess I better get somewhere and have all balanced. It just seemed it was more than that because the new shocks made it worse. Thanks everyone.
