mirror swap
Old Oct 26, 2007 | 10:07 AM
99hicksf350's Avatar
99hicksf350
Question mirror swap
need a little help with the wiring when swapping 06 mirrors on my 99, do they make a adaptor or does it need wires ran for the signal, and heat, or what, any help is appreciated
Old Oct 26, 2007 | 11:39 AM
Franklin2's Avatar
Franklin2
It definitely needs circuits for each function. You may have to hand wire this, I don't know if your truck has a plug in harness you can get from the dealer.
Old Oct 26, 2007 | 05:29 PM
99hicksf350
got it, thanks
just took a little time with a test light to figure out the mirror controls, and had to run 2 wires to each side for the running and signal light, the heat comes on with the lights so it took about 1 1/2 to do both sides, not too bad really, thanks
Old Oct 26, 2007 | 07:28 PM
Franklin2's Avatar
Franklin2
Thanks for the info on that.
