Sponsored by: Auxito
broken manifold studs...
Old Oct 26, 2007 | 08:53 AM
150mudder's Avatar
150mudder
well yesterday i was doin some work on my truck and noticed that on the passanger side my rear two manifold bolts are broken. well i was thinkin of putting headers on it but was wondering if anyone had suggestions on the type to get? never really searched for headers but now they are definately a possibility.
thanks.
Old Oct 26, 2007 | 10:20 AM
projectSHO89's Avatar
projectSHO89
Regardless of which headers you might install, buy stainless steel studs and replace them all while you're in there.
Steve
Old Oct 26, 2007 | 07:54 PM
RoyalFord's Avatar
RoyalFord
Were you able to get the studs out easy?
Old Oct 27, 2007 | 01:49 PM
superdutymj's Avatar
superdutymj
i had the same problem on my driver side manifolds. both studs on cylinder 4 were snapped off. With both studs they had snapped off flush with the manifold, so after i took the manifold off i was able to get a threaded stud puller on them and easily backed them out. Replace all studs and use felpro gaskets as the manifolds aren't machined real precisely and the factory shims likely didn't shim it up right and the heat made the studs pop
Old Oct 28, 2007 | 10:10 AM
150mudder's Avatar
150mudder
i need to get mine one but moneys kind of an issue for me right now. so i might have to wait a little.
Old Oct 28, 2007 | 01:27 PM
Ultramagdan's Avatar
Ultramagdan
Don't wait too long or you will damage the head. Since the stud broke you now have an exhaust leak and it will do $$$$ damage.
Old Oct 28, 2007 | 02:27 PM
Kijutsu's Avatar
Kijutsu
What kind of damage?
Old Oct 28, 2007 | 03:24 PM
Ultramagdan
It will burn a hole in the metal and then you need to replace expensive parts. Some members here have had this happen to them.
Old Oct 28, 2007 | 05:57 PM
150mudder's Avatar
150mudder
ahhh...by chance do you know how much putting headers on my style truck would be?? before i go calling around.
Old Oct 28, 2007 | 06:27 PM
Ultramagdan
You have the best source of truck parts here and who needs to call when you can find exactly what you want and have it delivered to your door via the internet.
Old Oct 28, 2007 | 06:30 PM
superdutymj
i think he means how much it will cost to install them. it took me about 2 hours to do one side, and im sure a pro could get it done much faster. it just depends on if and how many studs break off.
Old Oct 29, 2007 | 07:29 AM
150mudder's Avatar
150mudder
alright so at worst case senario im lookin at 5 hr lbr if every stud breaks, lol. well a guy i used to work with knows some people at an exhaust shop. ill go talk to them about gettin some headers and the lbr. ah...such an expense i dont need right now. but hey, its an excuse for more power though.
Lowboy44
Feb 26, 2012 08:49 PM
99FORD EXPY.
Nov 15, 2010 08:30 PM
topwhop
2004 - 2008 F150
May 29, 2008 05:32 AM
lsrjf
24
Nov 26, 2001 11:18 PM
71f100
Nov 9, 1999 06:38 AM
