Modular V10 (6.8l)
Electric Jacks Heads up
Old Oct 25, 2007 | 08:49 PM
barbicj's Avatar
barbicj
I sent this to another forum, but tought it may be helpful to RV owners on this list.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Here is a "heads ups" for you folks that have electric jacks. Before
leaving a campground Sunday, I was doing a walk around and discovered
that my right front jack did not fully retract. I recycled the jacks
and it went down but didn't retract at all. Bummer!!!!!
The jacks can be retracted manually and fortunately I had the correct
socket and wench. Unfortunately the extension I had was not long
enough to allow enough clearance from the surrounding parts of the
motorhome. I had only enough clearance for the wrench to rotate no
more than about a quarter turn. It took a long time, banged knuckles,
a blister and a lot of effort, to retract the jack. Needless to say,
I am going shopping for a LONG extension that will allow the wrench
to clear the motorhome and make a full turn. That will make this a
relative easy task.
It may be well worth your time to check how much clearance you need
to easily retract your jacks.
Regards,
Jack
2006 National RV SurfSide
Old Oct 26, 2007 | 01:47 AM
Sport45's Avatar
Sport45
While you're at the store get a speed handle to go along with the extension. (Looks like an old brace and bit drill.) It might be long enough that you won't need another extension.
Old Oct 26, 2007 | 03:43 PM
IHI's Avatar
IHI
18V cordless drill/impact driver....all you need is the 3/8 adapter to chuck it up, then all you have to do is pull the trigger and watch'er go
