Modular V10 (6.8l)
OIL weight HELP
Old 10-25-2007, 07:58 PM
bookum1's Avatar
bookum1
bookum1 is offline
OIL weight HELP
I have an 01 f250 V10. I bought the truck used and this was my first oil change. I looked at the sticker and it said 5-40 but the cap says 5-20. Wall Mart messed up and put 10-40 in it. I called Wal-Mart and they agreed to redo the change, but I am wondering what weight to go with. 5-40 that was in it when I bought it or 5-20 like is reccomended. I live in Louisiana and it rarely gets below 30 degrees.
I know someone can help me.
Old 10-25-2007, 08:34 PM
TeamMudd's Avatar
TeamMudd
TeamMudd is offline
i'd say have them put the motorcraft 5w20 back in it!
5w20 has been a great oil choice for me. MC oil is syntec blend, and it's about $2 per quart. but any 5w20 should be great!
Old 10-25-2007, 08:50 PM
boxcar1974's Avatar
boxcar1974
boxcar1974 is offline
If you run MC 5W20 you will never have anymore worries about oil weight ever again.
Old 10-25-2007, 09:44 PM
bookum1's Avatar
bookum1
bookum1 is offline
what does MC stand for?
Old 10-25-2007, 09:48 PM
boxcar1974's Avatar
boxcar1974
Motorcraft........sorry
Old 10-25-2007, 09:56 PM
bookum1's Avatar
bookum1
bookum1 is offline
Wal-Mat is going to put Pen 5-20 Syn blend, but I think I am going to ask for 5-30 because some have mentioned it for chain noise
Old 10-25-2007, 10:30 PM
Move over I'm coming's Avatar
Move over I'm coming is offline
Double check owners manual for your temperature (outside ranges).
The proper viscosity of oils (not weight as all weigh app. 3lb/qt.) will be on that chart.
Use the(( 5w (winter/pourpoint) 20 breakdown )) as it is best for our tight tolerance engines.
Old school thinking of using diesel oil 15w40 or the like will ruin our v10's.
Good-luck with your truck and welcome to FTE.
Rich.
Old 10-26-2007, 12:06 AM
swann79's Avatar
swann79
swann79 is offline
5W-20 is what is recommended, if you want 5W-30 you should still be OK. NO 10W- 15W- or 20W weight oils should ever go in these!
Old 10-26-2007, 08:54 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
I mentioned the chain noise, but my ear is tuned into it - it would never be noticed by the "regular" "normal" V10 user
Old 10-26-2007, 09:18 PM
44magnum's Avatar
44magnum
44magnum is offline
I have heard that we should change to thicker oil if the truck is close to 100,000 mile mark due to the tolerances getting larger.Is there any truth to this?
Old 10-26-2007, 10:22 PM
Sport45's Avatar
Sport45
Sport45 is offline
I've heard of folks running 200,000+ on 5W20, so I'd say it's not true.
I only run 15W40 in my '83 302 because of the flat tappet cam. I wouldn't change oil weight for high mileage. If the clearances are opening up due to wear changing oil viscosity isn't going to fix anything. It will only temporarily mask the problem and you'll wind up grinding journals undersize when you may have only needed bearing inserts.
Old 10-26-2007, 10:24 PM
swann79's Avatar
swann79
swann79 is offline
The only thing that would make me change it is if the truck starts using more than 1 quart between oil changes. I've never seen that happen on a well-maintained machine tho
SixDotEight
01-04-2013 09:43 PM
brapom
12-29-2012 02:55 AM
jeff299
16
01-07-2012 06:11 PM
95bigtime
19
11-05-2009 06:55 PM
78f250
Modular V8 (4.6L, 5.4L)
05-03-2003 12:34 AM
Quick Reply: OIL weight HELP
