1978 - 1996 Big Bronco
Front End Shake
Old Oct 25, 2007 | 02:34 PM
jstroud08's Avatar
jstroud08
Front End Shake
I run 33" street tires, and I noticed that whenever I applied the brake at low speeds the there was a popping sound coming from the right front tire area.
Now I have my 40" mud tires on, and when I drove it for the first time, the whole car started shaking after I hit a bump and I thought that my tire had come off or something. When I stop or get down to about 5 mph the shaking stops, and it only starts again when I hit a bump going over about 25mph.
I replaced the bushings on the passenger side, and now it is more noticeable on the drivers side, but the driver's side was fine before.
It is not the brakes, I just redid them.
No, the 40" tires aren't balanced, the tire shop couldn't handle them, any ideas on where to get them balanced? truck stop maybe?
Old Oct 25, 2007 | 06:07 PM
blue beast's Avatar
blue beast
It was always there on the drivers side it's just the other side took all your attention
If one side is wore out the other side is too, it has been exposed to the same amount
of oxidation, stress, etc. Stuff that has to do with brakes and suspension (safety)
items should be replaced at the same time. The bushings in the TTB pivots could
have some slop in them, Jack it up taking the weight of the front and with a big pry
bar see how much the left/right beams pivots can be moved, If you have a buddy
with the same front end jack his up and see what he has for movement. Having a
lift and bigger tires is an extra duty service schedule requirement for all systems in
your truck so change out the fluids sooner(esp. tranny and diffs) And that goes
more so for the front end parts, the extra forces exerted by the tires makes for more
wear on those bushings!! I had bad bushings on my shocks that let if I hit a bump
the front end would oscillate just that 1/4 inch or so it was pretty annoying I blamed
it on everything from out of round tires to balance to bad rad arm bushings to the
TTb pivot bushings, One day I looked as I was jacking up the truck and saw the
axle drop and then the shock caught up to it a second later, So I tried it again and
again. I took it off and it was ay bigger than the bolt. New bushings got rid of that
annoying little vibration. Daystar sells poly bushings I think they are $5.00 or so or
just go for a set of these http://www.eshocks.com/bil_ORvh.asp?...=All&SubChar=Q
They are going to be my next and last set of shocks since you can rebuild and revalve
them, Change the valving for conditions or change oil weight to really fine tune them
for different wheeling locations or weather even!!
Old Oct 25, 2007 | 09:02 PM
abnormloffrd's Avatar
abnormloffrd
combination of problems big tires not enough shock and stabilizer bushings and probably ball joints all the same things I went through and w/40's you should go poly and replace all the old any ways
Old Oct 25, 2007 | 09:43 PM
jstroud08's Avatar
jstroud08
i'll do that, i'm parking my truck all next week to do a tune up, and i'll add that to my list of things to do.
Old Oct 25, 2007 | 09:44 PM
jstroud08's Avatar
jstroud08
How should i balance my tires?
has anyone heard of or used centramatic balancers? do they work, or is there another product i should use
Old Oct 25, 2007 | 11:47 PM
abnormloffrd
put about 15 oz of semi truck equal balancing sand in each one it'll be close and better than any comp. dynamic bal bias tires will never bal completly and the equal will move to the lightest part of the tire even as it changes w/ speed
Old Oct 26, 2007 | 01:54 AM
blue beast's Avatar
blue beast
Do not put that equal in unless you have access to a good air supply that has no
moisture in it!! Or else that stuff will stick together and make the problem worse.
Try to find a good 4x4 shop with a strobeiscopic balancer and that trues the tires
if they are out of round, You can balance atire with weights all you want if it has
too much rubber on one area of the tread it will still vibrate at speed!! It needs to
be trued especially big meats like yours. How do you store your tires when you are
not using them? You should make a rack to keep the tire in the air that supports the tire by the rim center hole if you keep them mounted to rims, to prevent any flat spot or else you end
up with D shaped tires. If that is the case you need to get out and either do a
couple of burnouts or drive it for a good distance to get the tire heated up.
Old Oct 27, 2007 | 10:05 AM
helirich's Avatar
helirich
Do you have dual stablizers. You need them and they must be working. This is the number one thing to check/get. That doesnt mean you dont need to do all of the above. But it will probubly cure the simptons you discribe.
Old Oct 27, 2007 | 10:13 AM
helirich's Avatar
helirich
One other thing. I used that equal stuff and cant say I was impressed. I now balance my tires with a helicopter balancer. When I first started doing it that way, I had the sand in there. I would get differnt readings each time I started it. I never tried the concentric rings. They may be better. But I will tell you, no helicopter has such an arrangment. They certainly would if it worked. (Money is no object)
Old Oct 28, 2007 | 10:21 PM
thecardoc's Avatar
thecardoc
One more thing to check that I have not seen on here yet is track rod bushings
These are available in neopreme also.
