And I found out why I was low on fuel as now I have fuel coming out of a overflow that is coming from the fuel filter area and I haven't looked yet but I presume that there is a petcock that has not been turned all the way off when I had the filter replaced last month.
Dave
It may be the o-rings in the drainvalve leaking they can be replaced you don't have to buy a new drain valve.
If there is no tach movement when trying to start, is that an indication of a bad CPS? Mine is doing this right now and I'm not sure what to do. If it is the CPS, has has anyone had the recall Flash done to their trucks? Think it would do any good?
Not sure what the recall flash is, but if you can get it to a Ford dealership they should replce your CPS free of charge and you can see if that helps.
