361 tranny
Old Oct 24, 2007 | 11:29 PM
scrapyardking's Avatar
scrapyardking
361 tranny
well there was no catagory for the 361 engine so i thought id ask in hear. Anyway i got this old engine out of a log truck and was just wanderin what transmition could i put on it so I can put it into a pickup truck. The tranny thats on it now is a big lookin ******* and i dont think it will fit.
Old Oct 25, 2007 | 12:50 AM
Aquaman78F100's Avatar
Aquaman78F100
I believe any tranny that fits an FE block would work, but im not positive.
Old Oct 25, 2007 | 10:58 AM
mcdonaldm's Avatar
mcdonaldm
the 361 is based on the FE big blocks. basically a medium truck version of the 360. so any FE transmission will fit this engine.
rgds
Mike
Old Oct 25, 2007 | 11:13 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
rgds
Mike
A 361 is from the FT engine family (330/361/391)
Transmatics instead of C6's.
Different engine/transmission mountings.
Bell housings and flywheels are FT only.
FT 4 speed transmissions (Warner & New Process) are similar, FT gear ratios are different than FE's.
Driveshaft and coupling shafts are completely different.
Old Oct 25, 2007 | 09:01 PM
trinogt's Avatar
trinogt
Weird.... Coulda swore I had a 391 FT bored to 4.13 (428 size), and it ran a C6...
reverse "105" on the front of the block and everything...
Old Oct 26, 2007 | 01:16 AM
NumberDummy
The FT engines were introduced in 1964 (replacing the Lincoln Y's) and used thru 1978. Not one used a C6.
There's no transmission application chart in the parts catalogs that list a C6 for a FT engine.
Transmatics (the name Ford used instead of Allison) were the only automatic used.
Old Oct 27, 2007 | 03:14 PM
trinogt's Avatar
trinogt
But according to all my sources, the bell housing pattern is the same for all:
332 V8
352 V8
360 V8
361 V8
390 V8
391 FT V8
410 Mercury V8
427 V8
428 V8
regardless of what transmission 'came' with the engine... So any FE transmission should work, no?
$Bruiser$
Sep 1, 2019 04:55 PM
jpenley123
Large Truck
Aug 29, 2011 08:38 PM
Adawson
15
Nov 9, 2004 05:15 PM
fordman428
Nov 18, 2003 09:40 PM
