Need Electrical ASAP
Old Oct 24, 2007 | 10:12 PM
jrv7874's Avatar
jrv7874
Hello,
I just got done replacing the positive battery cable assembly on my truck. In doing so I screwed something up. The truck starts a fires but then dies you let the key out of the start position.
I think the issue is at the starter solenoid on the fender. What terminals do the additional wires go to. The live wire from the battery goes to one big terminal. The little wire down to the starter goes on the other big terminal. The signal wire pushes on to the little terminal. But what terminals did the other wires go on. I think something is not on the right spot b/c of the way the truck shuts off in the ON position
Any help would be appreciated.
-James
Old Oct 24, 2007 | 10:20 PM
tjbeggs's Avatar
tjbeggs
The other wires should go on the with the battery cable side. They need constant power. But before you do that we need someone to check their truck for sure.
I will run outside and look quick
Old Oct 24, 2007 | 10:26 PM
tjbeggs's Avatar
tjbeggs
yes one side has the battery cable and all the other wires except the small red wire that goes down to the starter. so one terminal will have a small red wire. then the rest of the ring terminal wires go to the other terminal (battery wire,starter cable, and a few fuseable links)
jrv7874's Avatar
jrv7874
Damn, that is how I have it wired now. So where else could the problem be?
-James
Old Oct 24, 2007 | 10:52 PM
jrv7874's Avatar
jrv7874
more info
Went out looked everything over again. No loose or unattached wires to be seen anywhere. everthing is hooked up correctly at the solenoid.
Does anyone have an idea of what to look at next?
Old Oct 24, 2007 | 11:03 PM
MADVAN's Avatar
MADVAN
Test in run possition. See if pcm/idm is live.
Maybe it cracked from being overtight.
Just WAG's
Bill
Old Oct 25, 2007 | 07:30 AM
jrv7874's Avatar
jrv7874
Just WAG's
Bill
Ok so I verified that there is voltage at the glow plug relay and the power distribution box. Not sure which wire to check at the PCM and IDM to see if they are live.
I am also not sure how overtightening the nut on the solenoid would impact anything because all of the additional wires are hooked directly to the battery cable.
Any other Ideas?
-James
Old Oct 25, 2007 | 08:30 AM
Action4478's Avatar
Action4478
Are you getting a WTS & or a CEL ?....
Old Oct 25, 2007 | 09:29 AM
MADVAN's Avatar
MADVAN
You might have blew the fuseable link (12 gauge).
Some times they will just break when disturbed.
From the outside it looks good, but may not be. Test with your light or VM.
Bill
Old Oct 25, 2007 | 09:51 AM
ono_55's Avatar
ono_55
Overtightening the nuts on the soleniod will break the contacts on the in sideof it.
Don't ask how i know!!
Old Oct 25, 2007 | 10:08 AM
jrv7874's Avatar
jrv7874
Not getting any check engine lights. Wouldn't the fuseable links have to be good inorder to have power at the glow plug relay?
The truck still starts fine so I would think that contacts in the solenoid would have to be good.
It is like a relay that should be energizing isn't so the ON position is keeping the truck on
Old Oct 25, 2007 | 10:18 AM
MADVAN's Avatar
MADVAN
Check the links. The links are down stream (closest to batts) to protect up stream. Hope that makes sence. GPR has its own set of links.
Bill
Old Oct 25, 2007 | 10:31 AM
jrv7874's Avatar
jrv7874
Ok I will check the links when I get home tonight. Do you have a part number for the links if one or more happen to be bad?
-james
Old Oct 25, 2007 | 03:23 PM
Cuda_jim's Avatar
Cuda_jim
If the fusible link is burned you may have some serious wiring problem....but if it just broke...no big deal. Fusible link is a short section of wire that has a smaller diameter than the rest of the circuit. You don't need to go to Ford for replacements. Some auto part stores carry them. Here's a link to more info:
http://www.madelectrical.com/catalog/fusible-link.shtml
