Still having electrical problems!
Old Oct 24, 2007 | 06:10 PM
Lead Head's Avatar
Lead Head
The truck's computer, if it has one, which I'm assuming it does, uses tiny bits of power, even with the key off. So they light would probably turn on, even with the key off. But since its an IDI, I'm not sure.
Your best bet would probably to go some place like sears, and look for a digital multimeter that can read DC amps and miliamps
Old Oct 24, 2007 | 06:12 PM
Agemenon's Avatar
Agemenon
I have one...
Old Oct 24, 2007 | 06:35 PM
starmilt's Avatar
starmilt
your truck shouldn't have an ecm. but even if it did light wouldn't come on key off.
Old Oct 24, 2007 | 06:37 PM
Agemenon's Avatar
Agemenon
k, well I'll go buy a test light tonight and get this done before it gets dark. I'll keep ya posted.
Old Oct 24, 2007 | 06:48 PM
starmilt's Avatar
starmilt
how are you starting it in the mornings battery charger jump start ect. if you unhook cables at night will it start like it is supposed to. how cold is it up there in the mornings.
Old Oct 24, 2007 | 07:48 PM
Agemenon's Avatar
Agemenon
It has enough juice to carry it over the night and starts up fine the next day...ut by the second day, you can notice there theres some loss of power. I didn't end up getting to test out the fuse box, because when I came outta the store, it was dark and pissing rain...so I'll save that for tomorrow.
Old Oct 24, 2007 | 09:06 PM
dwaymar's Avatar
dwaymar
look at the voltage reg also known to short out and cause probs especially with a 120 amp alt most are set for 100amps
Old Oct 24, 2007 | 09:22 PM
somedude's Avatar
somedude
I took a multimeter to the battery terminals when the "wait to start" light was on, and I'd get an average of 8-10 volts,
if your batts went to 8 volt when the glow plugs came on they either need charging or they are no good
you should have two 800 cca batteries cca= cold cranking amps
you should be able two draw 400 amps from one battery for 15 seconds with out the voltage going below 10.5v
the glow plugs draw around 200 amps
A new battery will hold 11 volts during this test
allegedgenius
Jun 5, 2011 02:21 PM
Cruickie
19
May 19, 2010 07:28 PM
phoneman91
May 6, 2010 04:22 PM
ttocs388
1983 - 2012 Ranger & B-Series
33
Jan 4, 2009 08:19 PM
LonelyRoad2004
Electrical Systems/Wiring
May 20, 2004 10:05 AM
