Wiring
Old Oct 24, 2007 | 01:23 AM
topgunn's Avatar
topgunn
Question Wiring
I swaped trans from E4OD to zf5. No power to solinoed, left shift lever in park but no power. Also where is the fuel shut-off?
Thanks in advance.
Old Oct 24, 2007 | 10:18 AM
PLC7.3's Avatar
PLC7.3
Fuel shutoff is in the IP.......front wire drivers side (USA)
Old Oct 24, 2007 | 07:43 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I think the neutral safety switch is mounted on the transmission with the E4OD.
You need to jumper across the wires that went to the switch.
Old Oct 25, 2007 | 09:55 AM
topgunn's Avatar
topgunn
The schematic shows a red with light blue and white with pink. I tried jumping them but still no luck. I ran jumper wire to r/lb at solinode and used my meter with connuity signal. I got signal from r/lb and w/p at the plug that went to trans. Niether one was hot before I jumped them. I ran ground from battery and checked with meter, no juice. Is there a hot wire that I am missing? Thanks for info,Dave.I have chilton and hanyes but aparently not reading them right.
Old Oct 25, 2007 | 10:46 AM
PLC7.3's Avatar
PLC7.3
Checked the fuses in the engine compartment box......
