low oil pressure
Old Oct 24, 2007 | 01:35 PM
79f-250custom's Avatar
79f-250custom
low oil pressure
hey fellas
today i was taking off my box and when i was drving it up to my barn to pressure wash it i noticed it didnt have much oil pressure. my oil level is perfect so its not from low oil. how can i test if my gauge is broken or not?
and how hard is it to replace an oil pump?
thanks
Mitch
Old Oct 24, 2007 | 02:56 PM
Mil1ion's Avatar
Mil1ion
Attach a mechanical gauge to the TEE where the sending unit is to verify oil pressure.
Sometimes engine crud plugs the tiny orifice on the S/U
Old Oct 24, 2007 | 07:17 PM
rusty7983's Avatar
rusty7983
if your oil hasn't been changed in a while it thins out and pressure drops also.
Old Oct 24, 2007 | 09:25 PM
fyrrsqnet's Avatar
fyrrsqnet
how low is low? and what size motor?
Old Oct 24, 2007 | 09:30 PM
masterbeavis's Avatar
masterbeavis
rule of thumb for oil pressure is 10 PSI for every 1000 RPM. Flow of oil at idle is more important than pressure. Ignore it till you are ready to drop in the pan, polish the crank and roll in some .001 undersized bearings You are probably showing copper on the bearings. Start using heavier oil, like straight 40 or 50 when the pressure really gets low, for now upgrade to 20-50.
Old Oct 25, 2007 | 10:24 AM
79f-250custom
hows shell rotella t 15w40?
thanks
Mitch
Old Oct 25, 2007 | 11:16 AM
masterbeavis
messing around with oil with low oil pressure is a guessing game. I would run a thicker oil, and ignore the idiot light/gauge until your motor starts ticking loudly. (that wont happen unless you run low on oil) If you want your oil pressure to come up even higher, substitute one quart of oil with lucas oil stabilizer. That is some THICK stuff. I'ts about $30 a gallon.
Old Oct 25, 2007 | 01:59 PM
79f-250custom
ok i think ill dump in some 40 in there. how many quarts does my 390 hold?
thanks guys!
Mitch
Old Oct 25, 2007 | 03:36 PM
masterbeavis
your engine can hold about 6 gallons before its full, and wont take anymore. Seriously, buy 7, start with 5 qt.
Old Oct 26, 2007 | 04:41 PM
79f-250custom
this thing only holds 5-7 QT? man i really kinda though she would hold like 7-9 QT.
but thank you!
Mitch
Old Oct 26, 2007 | 05:19 PM
Mil1ion's Avatar
Mil1ion
No he was being funny (Kind of)
He meant Gallons if one was to fill that engine Right to the TOP.
Rule of thumb is 5 US Qt's w/o filter 6 US Qt's w/ new filter
In Canada is was always 4 Imp Qt's w/o filter and 5 IMP Qt's w/new filter
One should always pour some oil in the filter before installation so oil is immediately being pumped thru it.
Old Oct 27, 2007 | 11:28 PM
79f-250custom
well i put in some 15-40 and still dont have very much pressure. hopeing the gauge is messed up.
thanks for the help
mitch
Old Oct 28, 2007 | 12:28 AM
fordhoor's Avatar
fordhoor
worn cam bearings. guaranteed.
Old Oct 28, 2007 | 09:05 AM
masterbeavis
You aren't going to have much pressure until you put in some super thick oil. Even then, you will have good oil pressure at idle only for a few hundred miles. For the winter, I would leave the stuff you have in for now. In the summer time, switch to the straight weight oil.
This chart is in Celcius, the lower in Fahrenheit.
