6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Programmers, etc.
Old Oct 24, 2007 | 10:22 AM
Black450's Avatar
Black450
Programmers, etc.
Has anyone hooked up a programmer or done anything to they're 6.4 yet? I've been waiting for Banks to come out with they're new products but no such luck. Anyone have an opinion on Bullydog or any of the other programmer companies? Thanks, Sam.
Old Oct 24, 2007 | 01:03 PM
2008drkstone's Avatar
2008drkstone
i have SCT Livewire Extreme all i can tell you is hold on! i installed on Oct. 16 with 9000miles. and so far have had no problems and lots of fun
Old Oct 24, 2007 | 05:24 PM
Black450's Avatar
Black450
Did you have to install any gauges along with it? Fuel economy improve at all?
Old Oct 24, 2007 | 09:36 PM
SouthTexasDiesel's Avatar
SouthTexasDiesel
SCT LiveWire is #1 for the 6.4. Got one for my 6-speed and this thing gets now. You don't have to install any gauges, there is an optional EGT sensor that they reccomend you install if you run the 120hp race tune, but I haven't installed my EGT yet and mine runs fine. The LiveWire is it's own gauge cluster, giving you all kinds of information to view, even regeneration status and DPF pressure. Slight increase in MPG, I went from 17.5 to 18. Not much, but that's running the 80 hp tune all the time.
Go with SCT, it makes my dually smoke all 4 rear tires.
Old Oct 26, 2007 | 12:32 PM
cHiLi 11's Avatar
cHiLi 11
All this new power is great, but with no new noise I am still sad....
Nick
Old Oct 26, 2007 | 03:07 PM
ljstoy's Avatar
ljstoy
Chilli, did you ever put an exhaust on yours? It took my Magnaflow about 2000 miles and obviously alot of regens but it's changed alot. Still nothing like my 6.0 with a turbo back 4" but I'll take what I can get.
Old Oct 27, 2007 | 12:53 PM
SouthTexasDiesel
Give it a month. You'll start seeing more DPF delete tunes, there should be some coming out for the LiveWire very soon.
Old Oct 27, 2007 | 07:16 PM
No1Hookman's Avatar
No1Hookman
If they have DPF delete tunes, you might as well delete the DPF. Anybody besides KEM have a pipe to delete the DPF??
Old Oct 27, 2007 | 07:58 PM
SouthTexasDiesel
That's kind of the point. Both are required to make the truck run properly without the DPF. It would be useless to release a DPF delete pipe when a tune isn't available to make it work. Most companys will be selling the set-ups as packages. I've been told that SCT is working with MBRP so they can sell it as a combo.<o =""></o><o =""></o>
Innovative Diesel is testing their DPF delete tune right now, and they will be offering various diameter delete pipes including 4" to go with the stock 4" down pipe on these rigs.
Old Oct 27, 2007 | 08:16 PM
No1Hookman's Avatar
No1Hookman
Sarcasm, my friend.
SRBF150
19
Aug 7, 2019 08:58 PM
xtamer
Dec 19, 2017 08:46 PM
Vin Diseal
Aug 5, 2015 07:33 PM
kadrocker
Dec 5, 2009 09:56 PM
otpracer100
Dec 1, 2007 02:35 PM
