Heat, lots of it. The clamp dents both pipes and holds them together. Then pry it off if you are trying to save the cat (recommended). OR beat the crap out of it (not recommended).
dang it farm! i was gonna say sawzall. but the slots work good too and you can spread the pipe with a chisel after the slits are made then if for whatever reason you did want to reuse the kitty you could just tac the slots up with your mig
im getting ready to put in a cat delete pipe but the cat doesnt want to come off of the back half of the exhaust. whats the best way to break it lose
I removed mine awile back tryed everything heat, cutting slots with a die grinder air chisel no go. Just take a sawzall cut it off just behind the joint where the cat goes, then get yourself some flex pipe and two easyseal clamps and your done.
Tie all that crap to a telephone poll and drive off!!! Thats what I did but was not thinki long night and dumb!!! I was lucky I didnt screw and thing up expecially where it connects to the turbo!!!
