CLicking when key in on
Old Oct 24, 2007 | 06:10 AM
jmethe's Avatar
jmethe
When I am trying to start my truck after the 'Wait to Start' light goes off, there is a clicking. I traced it back to the rear of the motor and there is a piece zipped tied on. Not sure if it is bad.
Old Oct 24, 2007 | 08:20 AM
PLC7.3's Avatar
PLC7.3
That is normal start proceedure of the GP controller..... once the WTS light goes out start the truck...it's waiting for you.
Old Oct 24, 2007 | 10:24 AM
jmethe's Avatar
jmethe
Thanks
Still a newbie to this diesel thing
Old Oct 24, 2007 | 06:15 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Be carefull - under the black plastic box is a connection which is DIRECT from the battery.
Old Oct 25, 2007 | 09:15 AM
j-redsjeep's Avatar
j-redsjeep
its your glow plug relay, how long is your light staying on? if it short and clicking you might have some burnt out glow plugs. it should stay on for 10 sec or so.
Old Oct 25, 2007 | 12:04 PM
matts156's Avatar
matts156
Mine did that when I first got it. I had two dead glow plugs. I don't know about the older controllers but on my 93, the clicking is not normal. It holds steady at around 9 volts. The two times it has started clicking since then, I've found a dead glow plug each time.
jjkreger
Jan 22, 2013 09:17 AM
broodog
Nov 20, 2012 05:43 PM
bluescrew
Nov 6, 2009 09:00 PM
05lariatPSD
Mar 20, 2008 11:08 AM
