Hpop Help !!!
Old Oct 24, 2007 | 12:14 AM
Badluck's Avatar
Badluck
Angry Hpop Help !!!
Hey guys tryin to take my <ACRONYM title="High Pressure Oil Pump">Hpop</ACRONYM> off tonight and wondering about the 18mm bolt on the gear how do i get that off it just seems to turn the pump is it reverse threaded??? need to get this thing off tonight so any help is greatly appreciated
Old Oct 24, 2007 | 06:35 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
A little late to your time constraints, but use a breaker bar and a 24mm socket to hold the crank. Things will torque up a little bit and then the bolt will break loose. Do NOT drop the washer.
