Wheel alignment on 93 Ranger.
Old Oct 23, 2007 | 10:19 PM
savagefan's Avatar
savagefan
Thanx to board members here the trans problem is fixed. So now is camber adjustable on this 2WD by shimming? And how about different rated coil springs? this has a "D" rating and is way too harsh, any preferences out there for this 2.3 equipped hot-rod?
Old Oct 24, 2007 | 06:25 AM
Dan Robertson's Avatar
Dan Robertson
As far as I know, at lest on my 98 2 Wheel drive (coil spring front suspension) the only adjustment for front end alignment is toe in and toe out.
Old Oct 24, 2007 | 07:41 AM
Pablo-UA's Avatar
Pablo-UA
RIDING HEIGHT SPECIFICATIONS TABLE ---------------------------------------------------------------------- Application Front (1) Lean Aerostar ...................... (2) .................... (3) 0.75" Bronco ..................... 3.8-5.5" .................. (3) 0.75" Bronco II & Ranger ......... 2.8-5.2" .................. (3) 0.75" "E" Series E150 ..................... 3.5-5.5" .................. (3) 0.75" E250/350 ................. 3.3-5.3" .................. (3) 0.75" "F" Series (2WD) F150 ..................... 3.8-5.5" .................. (3) 0.75" F250 ..................... 3.1-4.7" ................... (3) .75" Super-Duty ............... 3.1-5.5" .................. (3) 0.75" "F" Series (4WD) F150 ..................... 2.9-4.5" .................. (3) 0.75" F250 ..................... 4.9-6.8" .................. (3) 0.75" F350 ........................ (2) .................... (3) 0.75" (1) - Maximum side-to-side height difference with vehicle empty. (2) - Information not available from manufacturer. (3) - When measured at center of front wheel house opening. Maximum side-to-side height difference at center of rear wheel house opening is 0.63".
Old Oct 24, 2007 | 07:45 AM
Pablo-UA's Avatar
Pablo-UA
Bronco II & Ranger 2WD
APP. Fraction Decimal
Camber (Degrees) ......... 1/4 ¸ 1/2 ............... (.25 ¸ .50)
Caster (Degrees)(1) ...... 3 1/2 ¸ 1 ................. (3.5 ¸ 1)
Toe-in (Inches) ........... 0 ¸ 1/8 .................. (0 ¸ .13)
Toe-in (Degrees) .......... 0 ¸ 1/4 .................. (0 ¸ .25)
Old Oct 24, 2007 | 07:47 AM
Pablo-UA's Avatar
Pablo-UA
All wheel aligment data, I have. Before aligning be sure tires are inflated properly, frame is not bent, no play in suspention/steering, rims are ok...
Good luck!
Old Oct 24, 2007 | 05:26 PM
savagefan's Avatar
savagefan
Awesome, so how do you adjust camber?
Old Oct 24, 2007 | 07:41 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
Your '93 has the twin I-beam suspension.
Camber/Caster May or may not be adjustable, depending on whether or not an offset upper ball joint mount has been installed. If the offset mount is installed, it's a simple matter of loosening the nut, and rotating the mount.
If not, then you'll need to remove the nut, hammer the old mount out, hammer in a new, offset mount (you'll need an alignment check first to determine how much of an offset to install)... then rotate the new mount to get the alignment in specification, then tighten the nut.
An experienced alignment technician should be able to handle all of this for you (at additional expense, of course).
Good luck
Old Oct 25, 2007 | 01:37 AM
Pablo-UA's Avatar
Pablo-UA
As I remember it is ajusteble with semi-grommets put under the upper cotroll arm nuts...
Old Oct 29, 2007 | 07:34 PM
savagefan's Avatar
savagefan
Thanx guys, time to get greasy!
N2S3
Jan 25, 2017 12:43 PM
Dflynn926
Jan 21, 2016 02:27 AM
kwrules
6.2L V8
May 11, 2011 12:55 PM
fordguy76
Jan 30, 2004 11:40 AM
