heater core replacement
Old Oct 23, 2007 | 07:30 PM
arkredneck's Avatar
arkredneck
i was wondering how hard it is to replace a heater core in these trucks do you have to take the whole dash apart? i can get the core for under $25 so it would be more than worth it if it's easy enough
Old Oct 23, 2007 | 08:53 PM
plowhand's Avatar
plowhand
Playing in the Dirt
It's fairly easy. Lets see if I remember everything. Remove heater hoses at the firewall and remove any sealer around heater core tubes. Remove the glovebox. Disconnect vacuum lines under glovebox and move out of the way. Place towel on the passenger side floor to catch any spiled coolant. Unscrew heater box, seperate and remove half. Pull out heater core. Install in reverse order. Hope this helps.
Old Oct 23, 2007 | 09:13 PM
97 HD's Avatar
97 HD
ive done it in an 89 f-150 it took me about 30 mins. its as easy as plowhand says if our trucks are made like the 89 gasser. ive never looked at mine to compare.
Old Oct 23, 2007 | 11:38 PM
97REDPSD's Avatar
97REDPSD
It's the same as the 89 .
Old Oct 24, 2007 | 05:21 PM
arkredneck's Avatar
arkredneck
just wanted to say thanks for the help guys it was really easy to replace
Old Oct 24, 2007 | 06:50 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Glad you got it done!
rcraft
Mar 30, 2014 03:55 PM
RA31925
Mar 5, 2013 08:28 PM
JasonBrod
1997 - 2003 F150
Oct 4, 2012 02:05 PM
73Riviera
Sep 8, 2006 02:08 PM
bkdk
1983 - 2012 Ranger & B-Series
May 19, 2006 01:11 PM
