FE Block casting's
Old Oct 23, 2007 | 04:55 PM
DrFord's Avatar
DrFord
Question FE Block casting's
Quick question. I have a FE block that I am about to sell and I want to know what the casting on the block mean. I want to be able to describe it as accuratly as possible. So I was wondering where the numbers are that I need to look for such as date code ext...
Thanks
Brian
Old Oct 23, 2007 | 05:42 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Casting numbers can be meaning less for block ID. Most were generic and used on different bore blocks. Some tho are paticular to a certain block. It's a mixed bag. Date code will tell you the year/month/date of the casting. Date code is below where the oil filter adapter bolts to the block. It's on the small angle area. You'll see a number/letter/number. This is the date code. Post what you find. The casting number will help timeframe the block too. It's on the right side of the block. Some blocks don't have a casting number so be aware oif that. Of course measure the cyl bores to tell exactly what you have. Once you know what to look for it's very easy.
Old Oct 23, 2007 | 06:23 PM
DrFord's Avatar
DrFord
Ok
Date code is: 6 A 11
Casting number is C6ME
I know that this was a 390. (Possibly a 390PI) and a fairly built one too. it had a nice set of stock heads, adjustable rockers, forged pistons, heavy duty rods, and a holley 750 carb.
Off the top of anyone's head, can you ballpark what I might expect to get from this block? It is standard bore, but will need to be bored out. Other than that it looks good.
Thanks again
Old Oct 24, 2007 | 04:53 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
66/Jan/11 is your date code. Good 390 blocks are around $200.
Old Oct 24, 2007 | 06:55 PM
convincor's Avatar
convincor
Thumbs up
FFR428, small world
Old Oct 24, 2007 | 07:32 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Originally Posted by convincor
FFR428, small world
Yep it is. Good to see ya here!!
1977 f-350
Nov 22, 2011 02:04 PM
jacob_9249
Jul 26, 2008 08:04 AM
ilikefordtrucks
Sep 15, 2004 04:23 PM
FE 390
13
Sep 26, 2003 08:51 PM
carrojp
23
Feb 21, 2003 01:34 PM
