Which switch for my '53?
Old Oct 23, 2007 | 03:58 PM
jnb53f100's Avatar
jnb53f100
Question Which switch for my '53?
Mid Fifties catalog shows two different brake light switches(hydraulic) one is supposed to operate at 20-50 psi( the higher priced one).The other must operate at a higher pressure, I'm not sure that is what I want/need with a power booster, though. Isn't the pressure higher in a system with power brakes? Not a big issue here but I'm just curious...... JNB
Old Oct 24, 2007 | 08:19 AM
AXracer's Avatar
AXracer
I'm not fond of a hydraulic brake light switch, they have a nasty habit of failing and/or leaking. Why not just put a mechanical switch on it for reliability?
To answer your pressure question: No, power and manual brakes use the same line pressure to stop, the booster just makes it less effort on the right leg to reach that pressure. The lower pressure switch turns the brake light on sooner giving the guy behind you a little more warning.
Old Oct 24, 2007 | 08:25 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford used the same brake light switch from 1948 thru 1967 on trucks, and 1949/65 on cars = C1AZ-13480-A (Motorcraft SW-24). It made no dif whether the vehicle had power brakes or not. The switch is available everywhere.
Old Oct 24, 2007 | 10:11 AM
56efffie's Avatar
56efffie
I went with the adjustable brake light switch mid fifty sells. Mounts between the floor and pedal arm. this switch is mechanical and seemed to be the most trouble free and reliable. They are $20 part# 0576
Old Oct 24, 2007 | 02:49 PM
jnb53f100's Avatar
jnb53f100
Okay...... maybe mechanical is the way to go here. I was leaning toward hydraulic but not any more. Thanks for your input everyone! JNB
