302 and C6
Old Oct 23, 2007 | 11:58 AM
slice73's Avatar
slice73
302 and C6
Is a C6 compatable with a 302?
-Paul
Old Oct 23, 2007 | 12:51 PM
Mil1ion's Avatar
Mil1ion
In the 80's I would say yes.
302,351W
They did use C4's behind 302's up intil 1986 but I don't know exactly what application ..whether it was just cars or continued in Trucks as well.
http://www.technicalvideos.com/ident...smission.phtml
Old Oct 23, 2007 | 01:13 PM
slice73's Avatar
slice73
I'm looking at a 1969 302 smb and using a 1978 C6. Apparently years are relevant.
Old Nov 2, 2007 | 11:43 PM
ramarado's Avatar
ramarado
Slice73, did you ever find an answer to your question? I'd like to know the same thing!
Old Nov 3, 2007 | 01:24 AM
johnboy427's Avatar
johnboy427
Yes if you have a small block pattern C-6 it will work behind any 302, there are also 385 and FE series big block C-6s and they will not work. I don't think years matter I am pretty sure the C-6 did not come out untill after the 5 bolt small blocks were gone in 1964 correct me if I'm wrong and 302s weren't around till 68. You will also need to find the correct flexplate.
-Johnboy
Old Nov 3, 2007 | 01:30 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
-Paul
Sure, and Ford offered a C6/302 combo on 1978/79 F100/150's.
Before anyone says I'm full of ____ here's the reference: 1973/79 Ford Light Truck Parts Catalog ~ Transmission Application Chart ~ Section A70, pages 15 thru 17.
C6: C = decade = 1960's / 6 = 1966. Introduced in the fall of 1965 on the new 1966 models. (C4 = 1964)
The 302 engine was introduced in the spring of 1968.
Old Nov 3, 2007 | 08:31 AM
slice73's Avatar
slice73
I found a 1972 302 and the c6 is still in my 1978 F150. It was mated to a 351M.
Thanks for all the replies.
Paul
Old Nov 19, 2007 | 12:26 AM
starmilt's Avatar
starmilt
302 will not bolt up to 351m c6
PCOEUK
New Member Introductions
Dec 25, 2014 05:37 PM
mamatried
Sep 10, 2013 05:21 PM
Nascort
Oct 11, 2007 11:01 AM
1flyfisher
Oct 25, 2004 06:37 AM
Nascort
Feb 25, 2004 08:33 PM
