Overhead console Fixed!!
Old Oct 25, 2007 | 03:50 PM
sixpack1's Avatar
sixpack1
My overhead console has no anything. Fuse is good and wiring looks good. Do you think it just took a dump? Just didn't come on one day...Thanks, Sixpack
Old Oct 27, 2007 | 09:32 PM
zx250's Avatar
zx250
Of the next Riffraff East
Have a look here ( https://www.ford-trucks.com/forums/4...-gone-out.html ). Like most stuff, it can be fixed, This one is simple and cheap.
Old Feb 28, 2008 | 02:41 PM
lees40's Avatar
lees40
Smile Ok, you guys have me convinced!
I'm having this exact problem with my 2000 Expedition. I'm going to try to fix it myself as per all of the wonderful instructions I was able to find here. Thank you to all of you!
Old Feb 28, 2008 | 03:55 PM
jhand124's Avatar
jhand124
Welcome to FTE. Fixing my display is one off the first things I learned on here. It's pretty easy, I had a regular sized soldering iron, so that made it challanging.
Good luck
Old Mar 1, 2008 | 04:06 PM
lees40's Avatar
lees40
Rats, unfortunately, it doesn't look I'm going to be as lucky as the others with this problem. I was able to remove the circuit board as per the instructions, but all of the solder joints look fine. There is a "discoloration" in the upper left corner of the display module itself... looks like it could possibly have been caused by something getting too hot... I suspect that something burned out on the display board itself. How do I get a new one?
Old Mar 1, 2008 | 10:41 PM
jhand124's Avatar
jhand124
Try pressing on the resistors while its plugged in too see if it turns on. I would check the Junk yard or other sources because they are $400 at the dealer.
Old Mar 2, 2008 | 07:49 AM
lees40's Avatar
lees40
And if pushing on the resistor makes it comes on, then the solder joint is bad?
Old Mar 2, 2008 | 07:57 AM
jhand124's Avatar
jhand124
That would be my guess, it's worth a try.
I was unable to soldier the old resistors back on because my soldiering iron was to clumsy, so I put the radio shack ones on.
I had one factory resistor that looked like it was attached and wasn't, it lifted up on one end with a small pick.
My display looked kinda cooked too, but I knew it worked because mine was intermittent, I could give it a whack and it would come on again.
I guess I would exhaust the easy/cheap route before searching for a replacement.
Old Mar 2, 2008 | 09:48 AM
lees40's Avatar
lees40
Weird. I plugged it back in and it worked - for a while. Then it seemed to work if I jiggled things the right way. I guess I'll try retouching all the solder points and see what happens. Can't make it any worse I guess!
Old Mar 2, 2008 | 12:17 PM
jhand124's Avatar
jhand124
You should have her licked if you get the resistors connected back up.
Good luck
Old Mar 2, 2008 | 03:10 PM
lees40's Avatar
lees40
Heh.. still giving me headaches. Think I found the culprit though. Near the edge of the board where the button is, there are two little black rectangles with a "510" on them. When I push on the one the display comes on, and man is that little black thingy hot!
Old Mar 2, 2008 | 03:19 PM
jhand124's Avatar
jhand124
Those are the resistors. Are you using this link to figure out how to do it?
Old Mar 2, 2008 | 03:33 PM
  #28
lees40's Avatar
lees40
Thank you, now I can see the pictures! Mine looks a little different though and like I said, mine have a "510" on them. I tried fixing the one in question, and now it works, but, it blinks off about every 10 seconds. Do you think I just need to solder it better, or should I replace the resistor?
Old Mar 2, 2008 | 03:37 PM
  #29
jhand124's Avatar
jhand124
It doesn't sound like it is quite right if it's intermittent, try soldering it better if that doesn't work then I would go the Radio Shack route.
Old Mar 2, 2008 | 03:39 PM
  #30
lees40's Avatar
lees40
Thank you so much for your help, I pulled it back down and am reheating the soldering iron now.... keep your fingers crossed for me..
