I had my tranny flushed on the SD @ 30K. Now I'm approaching 60K, and thinking of doing a good old fashioned tranny service.
Is there a drain plug on the torque converter? Is there a real advantage to swapping over to synthetic fluid? I pull my car trailer once or twice a month with a total weight of 8000 to 9000 lbs (trailer and vehicle).
I use Mark's method. But I do deviate slightly from his instructions. Rather than running until I see air bubbles in the clear line, I use a bucket that is marked at 3 quarts. I pump out 3 quarts, then add 3 more. I repeat until the fluid is clean. I personally have no problem with following his instructions exactly, but it made my assistant uncomfortable
