transmission
Old Dec 16, 2002 | 07:48 AM
Stephens's Avatar
Stephens
transmission
Old Dec 17, 2002 | 10:38 PM
yalebldg's Avatar
yalebldg
transmission
I have a '95 F150 I6 4.10 limited slip rear.
The tranny is automatic with overdrive. There is a button on the shifter to turn Overdrive on and off. What is this transmission?
What's the best way to maintain it?
Thanks.
Old Dec 17, 2002 | 10:42 PM
3006ROCKS's Avatar
3006ROCKS
transmission
I am pretty sure that is a E40D tranny.
Thats all I know.
How does your truck run with 4.10s?
What sort of mileage do you get?
Can you spin tires on concrete just by flooring it?
Garrett
Old Dec 17, 2002 | 11:47 PM
steve83's Avatar
steve83
transmission
ROCKS is right - it's most likely the E4OD, but it might be the 4R70W. Either way, keep it cool (trans cooler esp if you tow) and change the fluid. If it's never been changed and it's over 60Kmi, I'd recommend changing it and then again 1000 miles later to flush everything out. Then you can go to a normal schedule like every 30-40Kmi.
Aerostar
Aug 21, 2024 11:23 PM
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Mar 11, 2001 10:13 PM
