Transmission Question
I have spend a good amount of time working on truck ranging from 1965-1979. I never have worked on an 80-86 pickup truck before. A friend at school went and looked at a truck that is a F-250 custom 4x4 that is somewhere between the years between 1980-86. I am going to go look at it with him soon, but here are a few things that I do know.
It is a manuel 4 speed, and the tranny is shot
it is a V8
So for now, my questions are, which engines were they putting in these trucks, and what 4 speeds were in them? Is it still the 351-400M series and the 460s, or did they have 302's in them. what should I look for to be able to identify the engine down to the particular family (somewhere I read that all these have different amounts of valve cover bolts or something-any easy way to ID?)
Also, what 4 speeds were in them? is it between the NP 435 and the T-18, like the older trucks?
I'm sure more questions will come soon, this is a new era of trucks for me.
Thanks very much for the help in advance, and sorry bout the long post
Garrett Schorran
The 351m/400 have 8 bolts holding the valve covers on. The 302 and 351w have 6 bolts holding the valve covers on.
There is not that much difference in the engines, and they even used the 9 inch rearend till about 83 or 84 also. Then they used the 8.8 rear for the 1/2 tons. The only major difference is the 4wd twin I beam front suspension they used 1980 and up.
As far as trannies, the early years are the same as the 79 down, with the c6 and the granny 4 speeds. As the years progressed, they started using overdrive trannies, some of which are considered weak compared to the earlier non-overdrive trannies. The automatic overdrive they started using was the AOD. I don't know much about the manuals, except some of the 4 speeds were aluminum, and were basically a 3 speed with a overdrive 4th. I think later on they came out with a Mazda 5speed that is considered ok, but not that great for heavy towing.
351M/400 discontinued after 1982.
4 Speed Transmissions: Warner T-18 & T-19; New Process 435; Ford TS OD (single rail overdrive); Ford RUG Overdrive.
Post the VIN, AXLE and TRANS codes from the Certification Label. The codes will translate to what it had originally.
Thanks again
Garrett
Bronco's (U150), Econolines and F Series Trucks are all listed. Distinct parts for F100/350's and U150's are listed separate from the E150/350's which first offered a 351W in 1975.
Examples ~ Front Motor Mounts
80/81 F150/350; U150 ~ E0TZ-6038-C .. Engine Mount ~ with 4WD ~ Before 6/1/81.
80/86 F150/350; U150 ~ E4TZ-6038-H .. Engine Mount ~ 2WD Only
I can't scan my Ford microfiche slides, but your local Ford dealer will have the same info...either on a CD, printed catalog, or microfiche.
