X3 help!!!!
Old Oct 22, 2007 | 09:21 PM
Redrider910's Avatar
Redrider910
X3 help!!!!
Need a little help here. I got two X3 one for a 06 and one for a 07 off a Innovative diesel, When I go to load custom file I get a can't open file.
I talked to sct and Ted from Innovative and got the files re sent and upload them, but still get the same problem. Pre loaded tunes work no problem.
The X3 have the latest up date 1.1.109.
Mabey I'm a dumb *** and doing something wrong.
Thanks
Old Oct 23, 2007 | 06:38 AM
cak301's Avatar
cak301
You need to go too the sct website under support and select downloads then select the X3. You then need to down load the live wire/X3 updater software. The files need to be unzipped if they were sent to you zipped. When you get the updater downloaded click the live load tunes button. A box will pop up asking you which file you want to download and then there are three file name spaces. Give the file a name and hit program. Hope this helps.
Old Oct 23, 2007 | 10:45 PM
Redrider910
I got it now,, Had to reload the operating software and the firmware, then reload the custom tunes.
